Tesla wall connector gen3 overheating fix
Discussion in 'Supercharging & Charging Infrastructure' started by njhtran, Jun 22, 2020.
  1. double07
    double07 Member
    Mass
    My WC3 was replaced late Sept with the same issue that everyone is facing. After I reinstalled the replacement unit on Sept. I noticed that the firmware is older version 0.8.58. Soon after I set it up and running. I blocked the wifi on the WC3, so it won't get update. So far, I have not had any issue since and still running 0.8.58. I probably won't unblock wifi until the real issue was resolved. My WC3 HW is the F version.
  2. Impaler
    Impaler '20 MY LR Black/Black, 20" induction w/FSD
    Still working okay? I've been having the issues for a month or so now. And our garage is really cold, and the cable is not more warm to the touch than a cell phone charger. It starts at 48A (on 60A circuit), and within an hour, drops to 24A with the three red lights.
    I checked and I'm on 0.8.58+g2f475f6c93fd79. Is that the latest? It doesn't seem to have pushed anything else. I'll try Tesla tomorrow.
    I re-provisioned the TWC to check all the settings and verified it's connected to WiFi okay, and also is configured for 60A. Still having the issues. My electrician basically said it's Tesla's issue, but I might have them come out and check anyway.
  3. Impaler
    So I called the number mentioned before, and it was a quick 10 minute talk - they are pushing firmware 1.4.2 to the Wall Connector, which they say should resolve the issue. Within two minutes of the phone call ending, it was pushing the update. I'm on 0.8.58 so that's quite a jump in versions. Looking forward to it fixing the issue!
  4. PossumK
    PossumK Member
    Long Beach, CA
    The latest firmware helped in my case, but didn't fully fix the problem. I still see the charge current drop slightly in warmer temperatures. In cooler temperatures it looks fine. I'd still prefer to be charging at the full rate, so I'm not settling with this fix just yet.
  5. Impaler
    Is it on 1.4.2?
  6. scissorfighter
    Maine
    Yes, as far as charging is concerned. The HPWC web GUI seems to be broken though, all I can see now is model # and SN on a screen with an infinitely spinning wheel. Go figure.
  7. Impaler
    Ugh...well, so long as it charges at 48A, that's all that matters to me.
  8. PossumK
    PossumK Member
    Long Beach, CA
    Yes, that was pushed into my charger after I called the support number. I waited a few months to see what others experienced as far as support and results before finally calling in myself.
  9. PossumK
    PossumK Member
    Long Beach, CA
    Just took a look today, it's actually on 1.4.0-10, with no update available when checking on the charger's page.
  10. StanMI
    StanMI Member
    Michigan
    Here we go again !! Back to slow charging after about a hour.
  11. StanMI
    StanMI Member
    Michigan
    Where/how do I find out what firmware I'm on?? Is it in the App ??
  12. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Use your router to find the network IP address of your wall connector. Then go to that IP address in your web browser.
  13. StanMI
    StanMI Member
    Michigan
    Thank you !! Looks like I'm on an older version. Call to Tesla due Monday. Thanks for the help !
    Happy Holidays to all !!
  14. Pluturi
    Pluturi Member
    Upstate NY
    When I do this all I get is a nice picture of the HPWC and the part/serial numbers followed by an infinitely spinning little circle. Any ideas on how to get the rest of the configuration?
  15. Art_Vandelay
    Art_Vandelay Attractive Membrane
    Elon’s left eyebrow
    Unfortunately this method got messed up with a previous firmware update. The only way to get the full configuration menu is to connect directly to the Wall Connector's WiFi network.
    To have the Wall Connector broadcast its SSID again, hold the button on the charging handle for 5 seconds.
    Once connected, just type the URL address: http://192.168.92.1 into your web browser.
  16. Trucu06
    Trucu06 New Member
    Florida
    I'm experiencing the same issue with the 3 red blinking lights and overheating, I just called Tesla and it seems that I have the latest firmware installed and they will send me a new wall charger because mine is defective. It looks like some they can fix with the firmware update and others have to replace completely, well not completely because the Tesla tech said they're going to send me just the face plate and that it was not necessary to replace back plate or do anything with the electricity.
  17. hybrid_eg
    hybrid_eg New Member
    Newport Beach
    I have the exact same issue as well.. I first saw it a month ago and thought it was just some random glitch but now its happening after 30 min of charging.. my software seems to be latest version and all electrical connections are fine.. house is brand new, run to main panel is super short and I'm just running a 50a breaker so 40a output.. surprisingly when the light started blinking the charge went down to 34A so little less than original charge amount.. nonetheless this is still problem for us as we need to make sure this thing is charging as fast as possible.
  18. CSFTN
    CSFTN Member
    Memphis, TN
    It January 24 and 35F outside, around 55F in my garage. Updated our 2 cars to 2020.48.35.5, and now both of my G3 WC are giving me a triple red blink with error codes in the car. Until today, I never bothered to hook them up to the internet (couldn't find the instructions with the passwords until I really looked); I have today and find they are both at FW 0.8.4 I don't have the option to "update firmware" and their respective web pages. Is there a way to force update other than calling Tesla in CA?
  19. Jones0812
    Jones0812 Member
    Boston
    Mine just did this today after working fine for 10 months
  20. garcialm
    garcialm Member
    Cleveland
    What gauge wire are you running from the main panel to the charger?
