Tesla Wall connector with nemo 14-50?
You could hack up an extension cord and connect it to your wall charger but it's not particularly safe to do so since the charger terminals are not designed to properly clamp the fine-strand wire of an extension cord. Plus those cords are expensive and you'd have to figure out a way to strain-relieve the entry point and...
A better approach would be to convert the outlet to a junction box by replacing the receptacle with a blank cover plate. You could then get some scraps of wire and a length of flex conduit to connect into the wall charger properly, legally, and in your preferred location.
Or just clip your portable charger to the wall and use that. The difference between the 32A portable charger and the 40A you could get from a wall charger in this configuration isn't meaningful in most cases. Overnight is overnight.
Reactions: Rocky_H
i happened to come to a youtube video where a person was installing the wall connector using a nema 14-50 cord, it was surprisingly simple. Then I googled more into it and found this link. Looks like at some point Tesla was selling a wall connector that is nema 14-50 ready? anyone happened to have it and share experience?
I watched the guys installing the 14-50 outlet in my garage. It was NOT that simple, and I would not do it my self. I paid $225, but it may be more in MA. Try not to mention the outlet is for Tesla as it seems to double the cost automatically.
This OP already has an outlet, on the outside of their home, and is likely looking for a wall connector with a pigtail because they already paid for the 14-50 install.
Reactions: Rocky_H
