Is there anything I gain by having my MY connected to a Tesla Wall Connector
vs directly to a NEMA connector and the portable charger that comes with the car,
other than not having to disconnect the portable if going on a long trip?
The
HPWC costs $500, plus the
installation, while the UMC ins included and could use an existing NEMA plug if you already have one.
HPWC maxes out at 11.5kW/48 Amps where as the mobile connector maxes out at 7.6kW/32amps.
For example, if your
daily driving is 180 miles (or 60% of 300 miles)
you would then charge at night from
20% to 80%, or 45 kWh, and it would take
4 hours at 48 A or
6 hours at 32 A.
So if you have a limited time for charging, for example your
ToU (Time of Use) discount
starts at midnight
but you
go to work at 5 am, then you should get the wall charger, otherwise the UMC would be fine.
Beside faster charging, but you need a 60 Amps line instead or 40 Amps line,
the real advantage is the
load sharing capability provided with the HPWC in case you have
two or more EVs to charge.
But again, this depend of your usage, as many users would alternatively charge each car every other day to use the dame HPWC.
