I’m on a long trip right now and won’t be back home for another 2 weeks. I left the car plugged in, set the charge limit to 70% with scheduled charging on.
Since the start of the trip, I checked on the car every now and then. It showed online and did not indicate anything abnormal. I also checked on the car charger (I use JuiceBox Pro that’s connected to WiFi and provides charging stats online and through an app) and saw that per normal charging profile, the car would top off to the charge limit every other day and draw some power every day for conditioning at the start of scheduled charging.
4 days after I left on the trip, I got a notification that a software update is available. Just doing my routine check in on the car (I know, I’ve been called a helicopter parent), I noticed that the car is offline. It’s weird since I have a WiFi router in the garage, but not unusual and it usually comes back online after a few minutes.
Check again on day 5 of the trip, and the car still offline. Check the car charger app, and it shows that the car has not drawn ANY power since the 27th.
I’ve been checking on the car ever since and nothing has changed. It has been about a week and a half since I left on the trip and the car has been offline for 6 days and hasn’t drawn any power from the charger for any of those days.
Checked the router, car’s MAC address is not registered on the router. Checked the blackvue I have installed and the dash cam is still online (at the moment) indicating the 12V battery hasn’t drained...yet.
Contacted Tesla, they see that the car is offline and speculates that the car has gone into deep sleep. They admitted chances are battery will be drained completely by the time I return and I will likely need a jump to the 12V battery.
(Interesting fact that I gathered from my call - Scheduled charging is controlled by the onboard electronics that turn off when in deep sleep. If the charging state at the time the car goes into deep sleep is ‘Not to charge’, it may remain that way even if the car has a charger plugged in and ready to provide power at the scheduled charge start time.)
I’m trying to arrange a Mobile Tech to go and check on the car (I have a garage facing camera and can open the garage remotely) but I haven’t heard back from the service center yet.
I normally see a battery drainage of 4-5% per day when I’m traveling in the summer while the car is plugged in. However, the garage temperature is around 50 degrees right now and is likely to drop more by the time I return so the drainage is probably much higher. Taking the previous drainage estimate, I expect my battery to hit deep sleep mode (5%) on Nov 9th. I won’t be returning home for another 5 days.
Here’s my question, how screwed am I?
Is battery damage inevitable? How much range loss should I expect to see? Anyone else have similar experience? Anything I can do remotely to get the car to wake up and charge?
