Tesla wireless charger issues
Discussion in 'Model S: Interior & Exterior' started by D Unit, Dec 24, 2020.
  1. D Unit
    D Unit Member
    Bay Area, CA
    I just finished installing it and it only works if I unplug the cable and then plug it back in. So basically, every single time I go inside the car, I have to unplug and then plug it back it for it to work. Sigh. Do you guys have any issues with this? wireless charger.PNG
  2. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    I installed mine several months ago and haven't had any issues. You might want to try plugging the USB cable into a cigarette lighter adapter to rule out a power issue with the Tesla USB ports.
  3. D Unit
    D Unit Member
    Bay Area, CA
    Thanks, that did the trick.
    But now I wonder what's wrong with my (2) USB ports. Both can charge my phone using a USB cable but for some reason has issues with the wireless charger. I suppose using the cigarette adapter is a better option anyways since I still need to use one of the USBs for sentry mode.
    Thanks again! Merry Xmas!
  4. DrComputer
    Sherman Oaks, CA
    You're welcome. Also, depending on which phone you have, you can get higher-powered (20 or 30W) cigarette lighter adapters than the built-in Tesla USB ports. So it can be a win-win using the adapter. Adapter Link
  5. VaztheDad
    VaztheDad Member
    Nashville, TN
    I thought I recall reading this part was only supported on one of the two USB ports. Just an idea, but does the issue crop up on both ports?
