Tesla Y 2021 gen 1 console 2 usb ports charging pad
Hello
Model y 2021 first generation console with 2 usb c ports : 1 is used to power up the wireless pad
I just got an iphone 13 pro max and it is not charging with a case ( it does charge without the case)
I’ve been looking a lot, made orders of wireless pads on amazon then cancelled them ( compatible with usb a ports etc.)
What is the wireless pad that will work on my car ?
Thank you
Thank you but the wood finish does not match the rest of the car 😔
Any other options ?
It doesn’t have a wood finish and it folds away. I’m talking specifically the MagSafe one.
JOWUA Invisible Foldaway Car Mount Compatible for MagSafe Wireless Charger, Compatible for Tesla Model 3 Model Y, Support Wireless Charging Smooth Silicone Surface Support iPhone MageSafe Metal Arm Amazon.com
And even though the install is pretty clean from a wire perspective, it’s easy to drop into the console so you see nothing.
Any option for a witeless pad that works with usb c ?
I have the jowua wood one that I used on my 2019 model 3. I know you mentioned you don't want wood. But it was the only good option I could find that utilized USB-C. I'll sell it to you cheap if you want it.
Had it for about a month before I sold the car so I still have the box and all the cables too with the airpod mount. It even has a microSD slot for sentry built into the bottom.
