In that case, it should be the same in the 3. At the same time, if it's reporting the usable energy reported by the BMS instead of averaging it and adjusting it for battery balance, battery temperature, and so on, it's likely not going to be accurate to use to compare capacity over short time periods.
An exception would be if someone can control for battery balance, temperature, and whatever else effects the capacity reported by the BMS. So if I charge to full, cycle it shallowly a couple times to help balance it at higher voltages, charge to full again (ideally on 120V to also give it time to balance), and leave it in my climate controlled garage for 12 hours before taking a measurement, that should give me a good idea of cycle and age related capacity fade because I'm controlling for things that can change the energy capacity reported by the BMS. If my measurements aren't controlled, then they're less likely to be accurate, especially over short timer periods.
