TeslaFi.com
arubinst
272
308
Ecublens, Switzerland
In Switzerland we had the problem, that it was not working with one provider (Swisscom). Then Tesla changed the provider (Sunrise) and it was working!
Seriously? Is that what happened? My car would never wake up from the App for the first couple of months!
Did they swap SIM cards? My MCU got replaced and I probably got the new SIM with it.
judyjetson
106
79
Charlotte, NC
I'm setting up a preconditioning schedule on Teslafi and want to make sure I'm going about it in the right way. here are the 3 schedules I've set...
Setting are for Mon-Fri.
1. Wake Car up 5:55am
2. Set HVAC to 65 deg. Fahrenheit at 6:00am
3. Turn on HVAC at 6:05am
Leave house between. 6:30 and 6:40am. I know this only allows for about 30 min. of preconditioning and Tesla states it can take up to an hour, however i want to limit battery loss and will start with 30 min. and adjust if needed. Would like to know if I'm missing anything.
pjw65
208
144
Switzerland
For current night temperatures (-3C/26F) during night, a Model S would heat up in 10-15 minutes (using up to 6 kW).
For -10C/14F 30 Minutes should be ok. 40-60 Minutes (start 2nd time after 35 Minutes) if it's colder.
AWDtsla
4,262
3,952
NE
That's entirely too long, and a huge waste of electricity.
It actually takes very little time to heat if the car actually sets the heater core to full power. Unfortunately up until a recent release, achieving full power (not set temp) would take 10-15 minutes. Purely a software bug. Now, I see that it achieves ~80% power in less than 3 minutes. Warm up time from 14F to 65F is 5 minutes. Still too slow in my opinion, but 60 minutes preheating is insanity. If Tesla fixed this, full power should be <5 seconds, and warm cabin in 1-2 minutes.
hiroshiy
2,376
1,476
Tokyo, Japan
Aside from the duration of preconditioning, TeslaFi schedule you proposed seems to be fine. I usually use 1 minute between those operations though and they work great.
ckoval7
Mild One
Sep 19, 2018
662
599
Maryland
I think "preconditioning" in the sense that it takes 40 to 60 minutes means running the battery heater to get it to a reasonable temperature.
Reactions: pjw65
judyjetson
106
79
Charlotte, NC
heating the battery is what i am referring to when i say "preconditioning". Apologies if I was unclear in my OP. I do not care about the cabin temp as much. But as far as I know, the only way to precondition the battery is to activate the cabin air. I'm trying to limit higher range loss and limited regenerative braking during colder temps.
pjw65
208
144
Switzerland
For that, you should just start charging in time, so that it just finishes when you want to leave the house.
Model S/X had also to uncheck "Range Mode" (not existing in M3, I think).
Forget preconditioning the cabin.
Cirrus MS100D
681
2,039
Pennsylvania, USA
That
That would require my wife to actually plug the car in everyday
Good to know that’s a “feature” in other households too. (TBF, mine also doesn’t remember to charge her phone at night and isn’t shocked when it’s dead by 9AM the next morning.)
Don’t get me wrong, mine’s a 11/10 in my mind and I would DEF marry again, but remembering to charge things and turn of lights ain’t gonna happen without a firmware upgrade.
judyjetson
106
79
Charlotte, NC
I don't believe those updates come OTA
thefortunes
1,072
1,266
Wisconsin
Plenty of upgrades currently available, unfortunately firmware is not one of them.
Reactions: Cirrus MS100D
David99
4,850
7,021
Brea, Orange County
Quick feedback/question.
In the Battery Report I noticed it recorded a recent charging session to 100%. I was in my car with my OBD scanner connected. I saw the car charged to 100% and finished at true 100%. The entry in the battery report shows 99% for some reason and then it uses that as a basis to calculate what 100% would be which is then 1% higher. For some reasons this seems to happen here and there. Any ideas why and how to fix it?
Reactions: hiroshiy
ibdb
Any excuse for a road trip
Apr 29, 2015
430
254
Puyallup, WA
@David99 I'd seen the same thing on my Model 3 until the most recent update I received 2 days ago. In two charging sessions on 2018.44.2 3b2a5c3, I'm seeing a 90% charge actually stop at 90% logged by TeslaFi. Before that update, 16 of 23 charging sessions beginning on 10/27 had stopped an indicated 1% short of what the car was set to reach.
NoBeard
327
486
McLeod HIll, NB
Hey,
Just signed up for Teslafi trial and when configuring I noticed in the settings that it says...
...one gallon of gasoline to contain 33.7 kWh, one imperial gallon of gasoline to contain 28.0611 kWh...
As one Imperial gallon is the same as 1.2 US Gallons, shouldn't there be 40.44 kWh in an Imperial gallon?
groovyd
347
151
Decatur, GA
I seem to get unusually low efficiency on my M3 even using autopilot for example this long trip from ATL to Macon and back... is this 70% efficiency on long auto-pilot trips normal or is there something wrong with my car? I was expecting at least 85% or better I guess since it wasn't a stop and go trip, just get on the highway and go.
GregRF
Squirrel Power
Jul 22, 2014
518
1,042
View attachment 357659 View attachment 357660
Looks like a combo of heating and driving fast, you've got long stretches at 80 mph, depending on configuration of your 3 you need to be doing 65-70 mph to hit rated range.
Reactions: groovyd
