groovyd
It would be really nice to know what the commonly accepted best TeslaFi settings are. I mean I set them to what sounded like the right idea but who knows for sure all the idiosyncrasies of it all.
Sleep problem here also after recent release. I’ll assume it’s 2018.48.12.1. After reading all the notes at TeslaFi it turned out that the car wasn’t even ‘trying to sleep’. I had to uncheck the two temperature items in the sleep parameters to get it to try then it tried immediately. Something must have changed recently?
I was getting weird HPWC charge results (wouldn’t top off to proper levels since the car was idle forever, never sleeping...) That part is fixed but now it attempts to sleep but still doesn’t ever do so. I’ve done all the TeslaFi settings recommended in the car (were already set): always connected off, energy save on, emergency overheat off, and also did new token for TeslaFi, and rebooted car for the heck of it.).
MCU 1, of course. Anyone see similar issues or have suggestions? This was perfect for a year until 48.12.
You mean you have the temp boxed checked or not? I had them the default on and with 2018.48.12 it wouldn’t try to sleep without UNchecking them.When I was on 2018.48.12.1 I hadn't noticed a difference in sleep patterns. On the vehicle side of things I have energy savings on and always connected off. TeslaFi side I already have the no inside and outside temperature boxes checked.
These are my sleep settings:You mean you have the temp boxed checked or not? I had them the default on and with 2018.48.12 it wouldn’t try to sleep without UNchecking them.
Then of course it still didn’t sleep. I’m now trying a longer sleep test period of 60 minutes from the default 30.
Well, as I said, no harm in turning on all three Sleep ‘sensors’: Shift State and Internal and External Temperature.Once you guys figure out exactly what works let us know so we can fix ours.
Dec 2018 will be MCU 2. Totally different.Mine seems to sleep on the "Outside Temperature Reading" option. Dec 2018 S 100D w/ AP2.5. Do you suppose it varies with the hardware version or installed firmware version? (I'm picking up what's probably 2018.50 tonight.)
What you can do is look in the TeslaFi data and see what values actually do go away.
Excellent, and/but I was also making a general comment for those that didn't know how to access the data. That menu option is a bit hidden.Indeed that's how I settled on Outside Temp.
Right, it must be that ‘sleep’ happens when the car isn’t doing anything and has no connection traffic (as in TeslaFi stops for x minutes). Why that isn’t happening some times with 48.12 is still a puzzle.none of those 3 are checked for me yet it does put the car to sleep after 30 min of idle.
Can you post a screenshot of the scheduler screen? You need to wake up the car and wait one or two minutes before executing any command.for me scheduled charging doesn't seem to work reliably. It appears to start charging roughly on time but then just stops 5 minutes later even though it is no where near the target charge level. When I go down to the car to see what's up the car is sleeping, not charging and when I tap my key card on the pillar it wakes and starts charging again.
