TeslaFi.com
Discussion in 'Model S' started by Jdeck, May 23, 2016.
  1. Zaxxon
    Zaxxon Supporting Member
    Colorado
    Yes, there's also a toggle to switch from scheduled departure to scheduled charging. I'm not near the car or I'd give you more specifics.
  2. r1200gs4ok
    r1200gs4ok Active Member
    Irvine California
    its at the bottom in very faint grey letter......tells you to push for set charger time
  3. cnwinger
    cnwinger Member
    SoCal
    Found the feature, thank you. So what does it actually do, specifically? I set it to start at 9AM. Then plugged it in at 11AM. I would expect it to wait until the following 9AM to start? But it started immediately. Is there a cutoff, like it only waits to start if you plug it in 12 hrs after or more, etc.?
  4. Zaxxon
    Colorado
    I believe it's 12 hours, yes.
  5. Mobile3228
    Mobile3228 Member
    Europe
    Or try to wait a couple of minutes after connecting. It probably stop charging.
  6. Zaxxon
    Colorado
    Yeah, good point. The car will always click the charger on when you first connect it if you've got a door open for hvac, etc. The screen will not say charging, though. It's just using shore power rather than battery power. This ignores scheduled charging limits (since it's not charging).
  7. hybridbear
    hybridbear Member
    Minneapolis
    We typically have our charging start time for around 5:00 or 6:00 am to finish charging right before departure. If we plug in again roughly before noon the car will want to start charging immediately. Right after plugging in you can stop this by tapping the "cancel charge" button on the screen. If you wait too long it becomes a "stop charging" button where the car will stop charging momentarily & then start again. The same is true in the app.
  8. cnwinger
    cnwinger Member
    SoCal
    Thanks for all the info everyone.
