simon.c
Just the default home directory from when I ssh in, though I did use sudo docker-compose up when I first ran it, not sure how that would have made a difference though. I still can't get anywhere with the grafana side of things though!
I assume MYDOMAIN is actually a replacement for what your domain is?
So it looks like the same error as mine. But you said earlier that it nevertheless works, Grafana too, correct?Well I know why it's not showing the correct certs now
version: "3"
services:
teslamate:
image: teslamate/teslamate:latest
restart: always
depends_on:
- database
environment:
- DATABASE_USER=${TM_DB_USER}
- DATABASE_PASS=${TM_DB_PASS}
- DATABASE_NAME=${TM_DB_NAME}
- DATABASE_HOST=database
- MQTT_HOST=mosquitto
- VIRTUAL_HOST=${FQDN_TM}
- CHECK_ORIGIN=true
- TZ=${TM_TZ}
volumes:
- ./import:/opt/app/import
labels:
- "traefik.enable=true"
- "traefik.port=4000"
- "traefik.http.middlewares.redirect.redirectscheme.scheme=https"
- "traefik.http.middlewares.auth.basicauth.usersfile=/auth/.htpasswd"
- "traefik.http.routers.teslamate-insecure.rule=Host(`${FQDN_TM}`)"
- "traefik.http.routers.teslamate-insecure.middlewares=redirect"
- "traefik.http.routers.teslamate-ws.rule=Host(`${FQDN_TM}`) && Path(`/live/websocket`)"
- "traefik.http.routers.teslamate-ws.entrypoints=websecure"
- "traefik.http.routers.teslamate-ws.tls"
- "traefik.http.routers.teslamate.rule=Host(`${FQDN_TM}`)"
- "traefik.http.routers.teslamate.middlewares=auth"
- "traefik.http.routers.teslamate.entrypoints=websecure"
- "traefik.http.routers.teslamate.tls.certresolver=tmhttpchallenge"
cap_drop:
- all
database:
image: postgres:12
restart: always
environment:
- POSTGRES_USER=${TM_DB_USER}
- POSTGRES_PASSWORD=${TM_DB_PASS}
- POSTGRES_DB=${TM_DB_NAME}
volumes:
- teslamate-db:/var/lib/postgresql/data
grafana:
image: teslamate/grafana:latest
restart: always
environment:
- GRAFANA_PASSWD=${GRAFANA_PW}
- GF_SECURITY_ADMIN_USER=${GRAFANA_USER}
- GF_SECURITY_ADMIN_PASSWORD=${GRAFANA_PW}
- GF_AUTH_BASIC_ENABLED=true
- GF_AUTH_ANONYMOUS_ENABLED=false
- GF_SERVER_ROOT_URL=https://${FQDN_GRAFANA}
volumes:
- teslamate-grafana-data:/var/lib/grafana
labels:
- "traefik.port=3000"
- "traefik.http.routers.grafana-insecure.rule=Host(`${FQDN_GRAFANA}`)"
- "traefik.http.routers.grafana-insecure.middlewares=redirect"
- "traefik.http.routers.grafana.rule=Host(`${FQDN_GRAFANA}`)"
- "traefik.http.routers.grafana.entrypoints=websecure"
- "traefik.http.routers.grafana.tls.certresolver=tmhttpchallenge"
mosquitto:
image: eclipse-mosquitto:1.6
restart: always
ports:
- 127.0.0.1:1883:1883
volumes:
- mosquitto-conf:/mosquitto/config
- mosquitto-data:/mosquitto/data
proxy:
image: traefik:v2.2
restart: always
command:
- "--global.sendAnonymousUsage=false"
- "--providers.docker"
- "--providers.docker.exposedByDefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.tmhttpchallenge.acme.httpchallenge=true"
- "--certificatesresolvers.tmhttpchallenge.acme.httpchallenge.entrypoint=web"
- "--certificatesresolvers.tmhttpchallenge.acme.email=${LETSENCRYPT_EMAIL}"
- "--certificatesresolvers.tmhttpchallenge.acme.storage=/etc/acme/acme.json"
ports:
- 80:80
- 443:443
volumes:
- ./.htpasswd:/auth/.htpasswd
- ./acme/:/etc/acme/
- /var/run/docker.sock:/var/run/docker.sock:ro
teslamateagile:
image: mattjeanes/teslamateagile:latest
restart: always
environment:
- TeslaMate__UpdateIntervalSeconds=300
- TeslaMate__GeofenceId=1
- TeslaMate__Phases=1
- Octopus__RegionCode=L
volumes:
teslamate-db:
mosquitto-conf:
mosquitto-data:
TM_DB_USER=teslamate
TM_DB_PASS=***PASSWORD***
TM_DB_NAME=teslamate
TM_TZ=Europe/London
GRAFANA_USER=admin
GRAFANA_PW=***ADIFFERENTPASSWORD***
FQDN_GRAFANA=***grafana.mydomain.net***
FQDN_TM=***teslamate.mydomain.net***
LETSENCRYPT_EMAIL=***[email protected]***
It's not a waste of time. You are saving me wasting my timehuge waste of time so far
It's vaguely possible that something recent has changed in the pulls for one of the containers which is stopping it working, perhaps?
This is my unedited docker-compose.yml file:
Code:version: "3" services: teslamate: image: teslamate/teslamate:latest restart: always depends_on: - database environment: - DATABASE_USER=${TM_DB_USER} - DATABASE_PASS=${TM_DB_PASS} - DATABASE_NAME=${TM_DB_NAME} - DATABASE_HOST=database - MQTT_HOST=mosquitto - VIRTUAL_HOST=${FQDN_TM} - CHECK_ORIGIN=true - TZ=${TM_TZ} volumes: - ./import:/opt/app/import labels: - "traefik.enable=true" - "traefik.port=4000" - "traefik.http.middlewares.redirect.redirectscheme.scheme=https" - "traefik.http.middlewares.auth.basicauth.usersfile=/auth/.htpasswd" - "traefik.http.routers.teslamate-insecure.rule=Host(`${FQDN_TM}`)" - "traefik.http.routers.teslamate-insecure.middlewares=redirect" - "traefik.http.routers.teslamate-ws.rule=Host(`${FQDN_TM}`) && Path(`/live/websocket`)" - "traefik.http.routers.teslamate-ws.entrypoints=websecure" - "traefik.http.routers.teslamate-ws.tls" - "traefik.http.routers.teslamate.rule=Host(`${FQDN_TM}`)" - "traefik.http.routers.teslamate.middlewares=auth" - "traefik.http.routers.teslamate.entrypoints=websecure" - "traefik.http.routers.teslamate.tls.certresolver=tmhttpchallenge" cap_drop: - all database: image: postgres:12 restart: always environment: - POSTGRES_USER=${TM_DB_USER} - POSTGRES_PASSWORD=${TM_DB_PASS} - POSTGRES_DB=${TM_DB_NAME} volumes: - teslamate-db:/var/lib/postgresql/data grafana: image: teslamate/grafana:latest restart: always environment: - DATABASE_USER=${TM_DB_USER} - DATABASE_PASS=${TM_DB_PASS} - DATABASE_NAME=${TM_DB_NAME} - DATABASE_HOST=database - GRAFANA_PASSWD=${GRAFANA_PW} - GF_SECURITY_ADMIN_USER=${GRAFANA_USER} - GF_SECURITY_ADMIN_PASSWORD=${GRAFANA_PW} - GF_AUTH_BASIC_ENABLED=true - GF_AUTH_ANONYMOUS_ENABLED=false - GF_SERVER_ROOT_URL=https://${FQDN_GRAFANA} volumes: - teslamate-grafana-data:/var/lib/grafana labels: - "traefik.enable=true" - "traefik.port=3000" - "traefik.http.middlewares.redirect.redirectscheme.scheme=https" - "traefik.http.routers.grafana-insecure.rule=Host(`${FQDN_GRAFANA}`)" - "traefik.http.routers.grafana-insecure.middlewares=redirect" - "traefik.http.routers.grafana.rule=Host(`${FQDN_GRAFANA}`)" - "traefik.http.routers.grafana.entrypoints=websecure" - "traefik.http.routers.grafana.tls.certresolver=tmhttpchallenge" mosquitto: image: eclipse-mosquitto:1.6 restart: always ports: - 127.0.0.1:1883:1883 volumes: - mosquitto-conf:/mosquitto/config - mosquitto-data:/mosquitto/data proxy: image: traefik:v2.2 restart: always command: - "--global.sendAnonymousUsage=false" - "--providers.docker" - "--providers.docker.exposedByDefault=false" - "--entrypoints.web.address=:80" - "--entrypoints.websecure.address=:443" - "--certificatesresolvers.tmhttpchallenge.acme.httpchallenge=true" - "--certificatesresolvers.tmhttpchallenge.acme.httpchallenge.entrypoint=web" - "--certificatesresolvers.tmhttpchallenge.acme.email=${LETSENCRYPT_EMAIL}" - "--certificatesresolvers.tmhttpchallenge.acme.storage=/etc/acme/acme.json" ports: - 80:80 - 443:443 volumes: - ./.htpasswd:/auth/.htpasswd - ./acme/:/etc/acme/ - /var/run/docker.sock:/var/run/docker.sock:ro teslamateagile: image: mattjeanes/teslamateagile:latest restart: always environment: - DATABASE_USER=${TM_DB_USER} - DATABASE_PASS=${TM_DB_PASS} - DATABASE_NAME=${TM_DB_NAME} - DATABASE_HOST=database - TeslaMate__UpdateIntervalSeconds=300 - TeslaMate__GeofenceId=1 - TeslaMate__Phases=1 - Octopus__RegionCode=L volumes: teslamate-db: teslamate-grafana-data: mosquitto-conf: mosquitto-data:
My edited .env file (fields with *** either side are changed):
Code:TM_DB_USER=teslamate TM_DB_PASS=***PASSWORD*** TM_DB_NAME=teslamate TM_TZ=Europe/London GRAFANA_USER=admin GRAFANA_PW=***ADIFFERENTPASSWORD*** FQDN_GRAFANA=***grafana.mydomain.net*** FQDN_TM=***teslamate.mydomain.net*** LETSENCRYPT_EMAIL=***[email protected]***
My .htpasswd obviously is just whatever login I want to be able to get to the TeslaMate website in the first place, and doesn't have to be the same password as anything else.
You can delete the teslamateagile stuff from the docker-compose.yml if you are not on Octopus Agile and/or don't want your charges automatically updated with real prices.
That's all I created in terms of files. I have always run docker-compose up as root.
Ok well I'm not sure what I did differently this time, but I appear to have it working and have also managed to import my teslafi data in too (well it's currently churning through it anyway - so fingers crossed it still works once it has finished). I'll run through what I think I've done - sorry done this so many different times now I'm struggling to remember what I've done differently each time! I've pretty much followed DaveW's list with a couple of minor adjustments...
- Create Debian micro instance (tick the http and https boxes): How to set up a free micro VPS on Google Cloud Platform
- Create two subdomains for your domain (teslamate + grafana) and point the A NAME records to your public IP of the Micro VM
- Install docker: Install Docker on a Google Cloud virtual machine - slightly amended this part of the guide based on some other guides for Docker on Ubuntu on GCP and included a "sudo apt upgrade" after the first sudo apt update, though I don't think that will have an effect as it only seemed to update a couple of google cloud things. I omitted running the hello-world at the end as I'd done it a hundred times already on previous attempts.
- Followed by:
- sudo apt-get install -y libffi-dev libssl-dev
- sudo apt-get install -y python3 python3-pip
- sudo apt-get remove python-configparser
- sudo pip3 install docker-compose
- Advanced install with Traefik, Let's Encrypt & HTTP Basic Auth | TeslaMate - I used the text from Durzel's post for the docker-compose.yml (minus the agile section) and .env files, though as far as I can see they are virtually identical to those on the Teslamate.org guide.
- Stop apache: sudo systemctl stop apache2 (don't think this line does anything as I presume it was related to the certbot stuff I had omitted earlier)
- sudo docker-compose up
- Once I verified it was up and running I used ctrl-c to exit back out but I found I had to use docker-compose rm -s to stop it properly at that point or else it wouldn't subsequently start up again when I tried sudo docker-compose up -d to run it in background.
- For the import I just used the ssh browser window to copy my teslafi csv files one at a time to the home directory (luckily only had the car 6 months so not too many files) and then "sudo mv *.csv import" to move them into the correct directory for the import process. To initiate the import had to restart teslamate so did another docker-compose rm -s followed by sudo docker-compose up -d to get back into teslamate.<whateveryourdomain.com> to initiate the import. Once it has finished it should just be a question of one last rm -s and up -d cycle, remembering to delete the csv files from the import directory before restarting it.
Many thanks @DaveW will report back once i go through it@Durzel - do you know what version of Debian you are running? I have managed to get this working fine for v9, but for 10 the lets encrypt just doesn't work! -
@davidmc @simon.c - be interested to see if the below works for you?
This is what I did to make it work on v9
Create your free tier GCP instance:
Create Micro instance, enabling http and https (tick boxes) Debian 9, disk size 30gb: How to set up a free micro VPS on Google Cloud Platform
Setting up subdomains:
Wait for the DNS to propagate:
After creating the ANAME records, you will need to wait until the DNS has propagated, you can test this by pinging teslamate.YOURDOMAIN, when it comes back with the GCP IP you've put in, you're good to proceed.
Docker install
Open SSH (browser is fine from the VM screen)
Run the following commands;
sudo apt update
sudo apt install apt-transport-https ca-certificates curl software-properties-common gnupg2
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] Index of linux/debian/ $(lsb_release -cs) stable"
sudo apt update
sudo apt install docker-ce
sudo usermod -aG docker $USER
Docker compose install
sudo curl -L https://github.com/docker/compose/releases/download/1.26.1/docker-compose-`uname -s`-`uname -m` -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
Now follow the instructions on TeslaMate: Advanced install with Traefik, Let's Encrypt & HTTP Basic Auth | TeslaMate
Launch with sudo docker-compose up
Once you've confirmed it works without errors, you can Ctrl+C to quit the compose session and restart it with docker-compose up -d
