I upgraded to the new Teslamate version (1.20) yesterday and am seeing the following minor error on the Overview screen. Anybody else seeing this?
select $__time(date), convert_km(odometer::numeric, '$length_unit') as "odometer_$length_unit"
from positions
where car_id = $car_id
order by date desc
limit 1;
I updated to 1.20.0 yesterday, there were no issues on the stock dashboards. I was putting off writing any custom dashboards until the new panel types in Grafana 7 were released. I had a quick play last night but unsure where some of the functions come from, and can't find a documented list of them.
e.g. convert_km - I thought this might be a stored procedure in the Postgres database since it is embedded in the SQL statement, however I can't seem to find the source of it. @DaveW do you have any experience of these procedures?
I've only made one proper custom dash and most of the data is just borrowed from the other dashboards apart from some custom calculations done using variables, but that is down to my 0 SQL knowledge, probably better / easier ways of doing it when you know what you are doing![]()
Was that a custom dash
Hi @DaveW I've just installed teslamate on a Raspberry Pi 4 using your guide on your site. Thanks!!!
I was previously running it on Vultr and would like to transfer my data. What would you recommend the easiest way to do it would be. (For a not advanced user)
Finally managed to resolve the import error.
- Deleted almost all of the data from the existing tables
- Changed the data type from `smallint` to `integer` in a few tables
- Re-ran the import
I now have all my TeslaFi data imported, next to focus on the front end.
Although I can see the benefits of using TeslaMate over TeslaFi the setup does feel a bit like a busman's holiday. If TeslaFi could update their UI and if the uncertainty over their rights to use the API were resolved, I'd be inclined to stick with them.
{%DBConnection.EncodeError{ message: "Postgrex expected an integer in -32768..32767, got 40507....
IIRC it imported successfully after running:I'm getting stuck on importing Teslifi data. Hoping you could help?
The error you had is the one sticking point for me.
Code:{%DBConnection.EncodeError{ message: "Postgrex expected an integer in -32768..32767, got 40507....
Do you recall which columns in tables you had to alter?
ALTER TABLE cars ALTER COLUMN id TYPE integer;
A huge thanks to @DaveW for taking time out of your day to help me get my Teslamate data transferred and getting it running on the Pi.
Was your car plugged in while updating? Sometimes Tesla firmware updates briefly start & stop battery charging many times during the update process, if a charger is plugged in.Updates Dashboard Issue,
Hi everyone my Model 3 just updated to 2020.40.3 last night and in Tesla Mate for some reason it shows I have had 9 charges on this new version. I looked in the DB and don't see anything apparently wrong, here are some print screens. Any idea how to fix it?
Grafana Dashboard:
Updates Table in TeslaMate DB, shows the update was between 09-OCT 00:51 and 00:58
Charge Processes in TeslaMate DB, wondering how it thinks I have 9 on the current version
I noticed the same error on my car. And it hasn't been plugged in for several days!Updates Dashboard Issue,
Grafana Dashboard:
If you try and connect to [email protected] without the .local (obviously replacing that nonsense with your pi's IP), see how you get on with that?
I'm still using the cloud for mine (Digital Ocean), so will struggle a bit to test
Hiya,
It asks me for the password for that login but I get password every time. Oddly I can type any random name and it will ask for the password - I guess this is a security feature.
Think I will have to start again, is there anyway to recover the Teslamate data direct from the SD card?
Hiya,
