I actually get pertty much the same message from Postgres about listening on a zero IP address: Code: PostgreSQL Database directory appears to contain a database; Skipping initialization 2021-02-13 17:02:28.275 EST [1] LOG: listening on IPv4 address "0.0.0.0", port 5432 2021-02-13 17:02:28.275 EST [1] LOG: listening on IPv6 address "::", port 5432 2021-02-13 17:02:28.283 EST [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432" 2021-02-13 17:02:28.304 EST [26] LOG: database system was shut down at 2021-02-13 17:02:27 EST 2021-02-13 17:02:28.310 EST [1] LOG: database system is ready to accept connections 2021-02-13 17:03:05.632 EST [33] LOG: incomplete startup packet 2021-02-13 17:04:05.176 EST [35] LOG: incomplete startup packet Let me show you all of my parameters and you can see if you have the same. Name: Postgres11 Repository: Postgres11 Network Type: Host Privileged:OFF POSTGRES_PASSWORD: secret POSTGRES_USER: teslamate POSTGRES_DB: teslamate Database Storage Path: /mnt/cache/appdata/postgres Web Interface Port: 5432 Name: Grafana Repository: grafana/grafana Network Type: Bridge (I don't know if this matters) Privileged:OFF Host Port 1: 3000 Host Path1: /mnt/user/appdata/grafana Key 1: http://192.168.1.99 (IP address of my unRAID server) Key 2: secret Name: teslamate Repository: teslamate/teslamate Network Type: Bridge Privileged: OFF DATABASE_USER: teslamate DATABASE_HOST: 192.168.1.99 (IP address of my unRAID server) MQTT_HOST: 192.168.1.99 (IP address of my unRAID server which also runs a MQTT broker) webui: 4000 import: /mnt/user/appdata/teslamate DATABASE_NAME: teslamate DATABASE_PASS: secret If you click the Basic View button in the top right to go to Advanced you can then add in the following, although these are more optional (this gives you an icon and a working WebUI link from the Dashboard page) Icon URL: https://assets.materialup.com/uploads/922c35bd-940d-4f26-bbd5-ff8b7075f53b/preview.jpg WebUI: http://[IP]:[PORT:4000]
Thanks a lot @wayner, much appreciated! I have exactly the same parameters but still an issue with database - 1) "teslamate role does not exist" (postgres log) and 2) "the database does not exist" (teslamate log). Thanks again but I give up and I will install Teslamate on a linux VM on my UNRAID.
Had lots of trouble with missed drives and charges but the new 1.21.5 update seems to have fixed that. The changelog mentioned some issues about login tokens expiring so I think that must have kept happening. Recommend updating asap.
A question on upgrading - I week ago I got Teslamate up and running on my unRAID server with a bunch of custom work. I see that there is an update of the docker package. If I run the upgrade is there any risk of breaking things? Or should I likely be good.
My Teslamate reports 'Health Check Failed' again. So how can I fix that? It fixes itself when I restart Teslamate so my guess is it is a bug in TeslaMate.
Are you running on a Raspberry Pi or such like? The SD cards are very susceptible to data corruption after awhile, (well a lot of the lower cost ones are). If this is correct then the SD is going bad. But I am guessing a bit here...
There was a problem wit the Tesla API or Tesla at the weekend. Details here: Login timeout issue · Issue #1369 · adriankumpf/teslamate
Has anyone figured out how change a price per kw/h? I added the price per kw in Teslamate but thought it was pence when it is set to £. At the time it updated all the previous entries for this location but now I can't figure out how to change them from £ to pence. I've tried removing and re-adding the geo-fence but no luck.
Depends what custom work you did. As long as you don't change anything and the docker file has all the same settings then updating it shouldn't be an issue. Saying that I've had permission issues previously when updating between versions and the like so I would make a full backup just in case.
Is there any way to send a notification when you get one of these Health Check Failed issues? It would be great to get notified so that you could try to fix it.
I am hosting locally in a docker but the web page is (or was) still up. It was just giving the Health Check Failed error. I guess I could write a python script to grab the page and parse the html for "Health check failed" but it would be nice to have TeslaMate send you an email or other type of notification.
Does anyone know if the servers are having issues? I am getting the following errors in my logs: 2021-02-28 18:08:32.838 [error] POST https://auth.tesla.com/oauth2/v3/token -> error: "timeout" (60196.284 ms) 2021-02-28 18:08:32.838 [warn] Token refresh failed: %TeslaApi.Error{env: nil, message: "timeout", reason: :token_refresh}
hi all, I hire someone here can point me in the right direction: I've installed teslamate via docker on my Synology NAS. I can see Teslamate working fine - but when I go to the Grafana dashboard, I get an error: "Error updating options: Metric request error" I've googled it but cant seem to find anyone else with this issue - anyone got any pointers? Thanks
I'm no expert by any stretch, but I used to get multiple errors like that too. IIRC it came after I updated Teslamate and most of them were from values being changed and my own 'dashboard' I created still using the old ones. I customized my grafana where I populated different panels from sections within TM so everything I find important to check is all on the one screen. I just copied the panels again which resolved my issue. I hope that helps, if not try giving it an update; docker-compose pull docker-compose up -d If that doesn't help then sorry, I'll see myself out and leave it to one of the pros here
The changelog said there was an incompatibility and then on the latest updated the grafana had to be downgraded to make compitbile, what version you on?
