teslamotors.com issues (canada)
Discussion in 'Canada' started by Beckler, Aug 11, 2015.
Tags:
  1. Beckler
    Beckler Member
    Canada
    Using Chrome, at Tesla Motors | Premium Electric Vehicles if I change the region on the bottom of the page to Canada (En) it isn't remembered and next session it goes back to US every time - highly annoying. I haven't disabled cookies or anything.
    Also somewhat related, I notice on the Model S page, the US version has a 'Charging Estimator' widget whereas for Canada it disappears. Probably because there's an electricity cost figure there which they don't want to deal with. But then if so, why not just have a value you can change? We can of course just use the US page, but who wants to deal with obsolete units like miles. :)
  2. Ehstrike
    Ehstrike New Member
    Calgary, Alberta, Canada
    Once I changed regions I bookmarked it as I was having the same issue therefore saving a step or two when I visit the page.
  3. SmartElectric
    SmartElectric Active Member
    Toronto,Canada
    I've raised a few issues with Tesla Canada regarding the incorrect listing of 40A charging via 14-50 adaptor. While the US adaptor can charge a Model S at 40A, the Canadian version of the adaptor supports 32A. This caused me to spend a few hundred $ that I didn't otherwise have to, as I already had a 40A circuit and wiring available from my panel, but didn't use that, as I mistakenly (due to the website and PDF's) believed the information to be correct.
    Tesla had fixed a few examples of this, but many still remain. They did agree to keep working on this...
  4. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    14-50 adapter with the UMC? I can pull 40 amps on my 50 amp outlet no problem.
  5. PoweredByRain
    PoweredByRain Member
    Victoria, BC
    Ditto. I have certainly seen 40A from the UMC with 14-50 plug.
    I don't think there is a separate version of the UMC for Canada. Either your circuit is not on a 50A breaker, or there is something broken somewhere...
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I charge at 40A on a NEMA 14-50 outlet every night.
  7. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Take a look at the fine print on your adapters. The new ones for Canada are downgraded to 30A. If you are charging at 40A then you probably have the original (US) adapter.
  8. Beckler
    Beckler Member
    Canada
    :D Good point! "http://www.teslamotors.com/en_CA"
  9. hingisfan
    Kingston, Ontario
    They just gave me a new one last month under warranty, and I am still charging at 40.
