MikeBur
ManualPilot
Okashira,
I appreciate you laying out the case that there is room for error in wk057's data or at least that there are variables based on his methodology which he has not yet presented here. I assume that you object the spot welder comment from MikeBur, because as far as I've seen you have not stated that you have tested cells and drawn 11.9Wh from them. Will you address that aspect of his post?
If in fact, wk057's testing methodology underestimates the battery capacity in a fashion that happens to be consistent with Tesla's own BMS does it then follow that if the true capacity of the pack is 85Wh, then his calculated capacity of 61Wh for the 60 pack should actually have been ~ 64Wh?
I do find it mildly amusing that, assuming you are correct, the answer to the 85 vs 81 debate will turn out to be essentially the same as the hp debate -- the batteries could theoretically produce that much energy, just only on a test bench -- never in the actual car.
Perhaps it was the spot welder comment, though it wasn't meant in a negative way, rather reminded me of inadvertently doing a little bit of unexpected spot welding that I did when working with high current DC many years back and it made me laugh. Never thought that going misty-eyed would cause such much pith, though ho-hum.
I completely align with the belief this may well be utopic, lab-equipment-and-special-cell-criteria-required, situation. I would like to know if anyone has, and under which circumstances, proven that these cells are tested capable of 11.9Wh. I don't find that a dumb question as this would be a fundamental prerequisite for proving the capacity of this battery. I'd actually like this to be the case, though fear this is not.
