ChadFeldheimer
So you got the increased range you wanted and you paid for but you are concerned that the battery rating difference may not be as much as advertised???
Hello!
No, I've never driven the EPA test cycle nor have I gotten anywhere near 265 miles.
If you could magically have a 87KWh battery but it had the SAME range, would that put a good taste in your mouth?? Didn't you get every bit of the additional range you paid for? This seems to be the foolish part...
EPA range estimates only have a loose relationship to real world range. To be clear, I'm not saying that the EPA range estimate is useless - that would obviously be unreasonable. But to go the other way and argue that EPA range estimate is the end-all-be-all is similarly unreasonable.
The point is that an educated consumer takes whatever datapoints are available to them and fuses them together as they best see fit to make their purchasing decision.
When I made my decision, I didn't have all the datapoints I have now. I thank all the technical contributors to this thread for that.
