jpet
Jan P.
Thanks, KB!
We don't know if lolachampcar went "all-the-way" during this session.
It can take quite some time to reach the 0A end-point at times.
4.197V seems to be the highest value.
It looks like CELL or brick #54 is just under 2.9 at 0%--i wonder if that is the low voltage fault setting in the main BMS?
Didn't you drive further and use up the 4kW anti-bricking reserve--How did you override the anti-brick to allow further driving?
And so your pack is fine after the torture test--and no cells hold at 4.2 for 100% soc?
my Tesla-scanner working in real time...
I think you need to make the video public. We get a "This video is private" note.
sorry...
now?
sorry...
now?
you think wrong. tesla has always stated 6.4 usable at 25C
stationary storage always states usable capacity going back to the days of lead and iron and sodium
Right, that is correct. It seems they are counting the round-trip efficiency of 92% in at 6.4kWh. However, hard to tell if it has anything to do with this thread or if things changed as it reached production (first deliveries just recently happened in Australia). Like I speculated with the S pack design, the Powerwall pack design may not have been finalized until recently.But on their website just a few days ago it says 7 kWh. 7 kWh has always been the "face value" since last year too.
If you are talking about datasheet then you are correct after doing some digging. Datasheet always stated 6.4kWh at 25C. Website ads stated 7 kWh. I guess you are both correct.I see what you mean and I apologize for misunderstanding. Yes face value has recently been updated, not sure if it is because of us or because legally if you advertise 7 that means 6.5-7.0+
6.4 must be advertised as 6 or 6.4, but the data sheet has always stated 6.4 since launch
Interestingly, a 20mmx70mm cell has ~33% more volume than a 18mmx65mm cell. Yet the rating on that cell would seem less than 33% more than the the 18650's that Panasonic currently sells.
It's not likely a strict function of volume, but the capacity limits may be thermally constrained by the surface area from which heat can radiate--the surface area increased about 20% and the capacity increased 21%.
