Uncle Paul
Tesla cameras are located to assist Autopilot. They can be repurposed for driver visualization, but will not be optimal for that purpose.
The same way land Rover can show you what's under the front of the car. By caching the images as it rolls forward
It shows lane markings painted on the ground and handicapped spots the same way
How do you propose the cameras, mounted at the top of the windshield, show you what's on the ground right in front of your front bumper?
I guess you should reread your comment. I mentioned nothing about 360.
The camera's in the windshield clearly see what's ON THE GROUND in front of the vehicle as it moves forward.
I
So my reply remains the same for pulling forward. It can cache the images and display if there is a concrete parking stop or whatever IN FRONT OF YOU
I'm good. I'm still sure the car can see a few feet in front of it and could see a parking block pulling forward without issue once it goes out of your line of sightif you're having trouble visualizing why this might matter and care to look
"Tesla owners may soon have the benefit of using the side cameras of their vehicles when backing up. Elon Musk confirmed that such functionality can be added in future updates after a brief exchange with a Tesla owner on Twitter."
Tesla to utilize side cameras to help drivers back up, confirms Elon Musk
I am very excited for this. It seems like one of those obvious features we should have gotten a long time ago.
Here's an example from one of green's videos. When the car is parked, it indeed cannot see the dividing line close to where a parking block would be:I'm still sure the car can see a few feet in front of it and could see a parking block pulling forward without issue once it goes out of your line of sight
I totally agree. The front camera behind the windshield is not sufficient for FSD in city driving.Go to about 12 seconds in, the car comes to an intersection and executes a right turn.
As you can tell by only "seeing" what that front camera can see-by the time it's far enough into the turn to see "straight" on the new lane,
it's missed almost an entire car-length of road that was never visible to the front camera
It can't tell you "what was just there" because the camera never saw it
This, again, is why Land Rover (and everyone else that does any sort of "low around the car" front parking view)
mounts the camera low on the front bumper, instead of the top of the windshield, to provide the kind of view you want.
Hello my fellow m3 owners. My 1st ever post here. I have owned my 2020 model 3 stealth since Nov 2019 and loving every day of it. Since we are in the topic of reverse cameras, I wish we had an option of leaving the reverse cam on along with navy screen. For now, it's either back cam or nav screen. Just a thought.
I know I'm right. I'm done arguing what exact scenario I've explained multiple times.But you're right that as the car is pulling into the spot, the main front camera would have been able to see the dividing line and parking block:
Is this why Teslas don't have pedestrian warnings and cross traffic alerts?
When you observe the Tesla advertising, it claims to have sensors up the wazoo and pedestrian alert.
If you've never driven a car with it, you not going to understand what it does.
The B-pillar has forward facing cameras, the blinkers rear facing cameras and the windshield has 3 different cameras. All camera's have overlapping vision. Definitely enough for FSD.
You as a driver are sitting 0.5 meter if not more behind those cameras and you do not have *any* issue with adjacent streets do you?
That can *only* be a problem if your speed is too high and even if you have a camera mounted all the way in the bumper your speed likely still too high.
So the camera placement is sufficient for most FSD tasks except parking in tight spots. Tesla's fail big time as the vision would not be able to provide enough info due to the large blind areas near to the car.
And even before turning into the spot, the wide fisheye camera and side pillar camera would be able to see the parking block even when the front main camera is pointing the wrong way:
Teslas answer to this (and, technically correct from a safety point of view) is that people should be backing into spots, such that they're pulling out forward.
It is factually safer to do even without any driver aids, and in a Tesla provides both the front radar and numerous front-facing cameras to handle cross traffic issues.
Indeed- if you use auto-park, that's how the car pulls into perpendicular parking spots...backward.
Backing in would be acceptable for many people who use sedans.
But for a car with a big hatchback cargo area and a trailer hitch, that is truly puzzling.
Ba
BTW - Cars with frontal radar also have cross traffic alert pointed forward. The car can see around parked cars better than the driver can. The lack of pedestrian alert in either direction is baffling. It's going to become Euro req IIRC.
Why?
If you don't have a trailer- there's no difference.
If you DO have one you'll need a 2-length spot that you pull through so you're STILL facing front-out when leaving.
Not quite sure what you're saying here?
The car DOES have front radar, and DOES stop for pedestrians in front of it...
https://electrek.co/2020/04/21/tesla-videos-autopilot-avoid-pedestrian-crashes/
