I have the car & the app set to display the temp in F deg. but the dashboard shows the inside & outside temp in C deg. can this be changed?
Your home page says that the trial is one month in one place and 15 days in another place...
Try TeslaSpy for a month for free!
Try TeslaSpy for 15 days for free
Thanks,I got it to change by switching back & forth a couple of times.You can set temperature units to F in the settings (see attached), but next week teslaspy will take the car's unit by default. thanks!
The Drives and Charges page doesn't load in the Android app if I have not charged or driven my car after signing up.
Me too - can't use the app. Maybe I need a drive/charge before it will work?
I'd love to see a minimum SOC for a given trip - can't seem to find that in TeslaFi.
Would you consider adding information about how you use tokens in the privacy policy?
after using tesla spy for a day and using teslafi for about an year this is what I miss:
1. on the dashboard - there number of drives, total driving time and distance for the day but no energy used
2. I want to have cost of energy per drive, day, trip month and year - I love to keep track on it. Also teslafi has nice calculation which tells you how much you spend on charging /at home in my case/ and how much you saved using destination chargers or superchargers.now it tells the cost of charging session if the charging location is tagged with energy cost / the format is x.xxx which should be $x.xx - only 2 digits after decimal/
Another thing that grabs my attention is the estimated range - it is over 60 miles less than rated range which I have no idea how was calculated but it sounds strange
Other than that /I understand that it is new platform and still developing/ I like it very much. If things noted can be implemented I will subscribe for sure
Hi
I have just subscribed and requested a token from Tesla.com. The web app is working but keeps saying "TeslaSpy is not collecting data from your Tesla". I go into settings and change the Fetch Data from Tesla setting to on - but after short time it seems to disable this setting and starts reporting the "TeslaSpy is not collecting data from your Tesla" message. How do I make the Fetch Data from Tesla setting stay on?
Thanks
Looks great. There are a few similar services out there. I personally use TeslaFi for a while now. Yours look great. You did a great job on the visuals and UI. I think that is important. It's easy to collect data, it's an art to present it in a meaningful way.
I started with Visible Tesla, a program that captures all data on your own computer. It worked OK but then a new version could not read my old data and I 'lost' almost a full year of data. I then switched to TeslaFi. I have 2 years worth of data from my car logged with it. I do not want to lose this again so I'm staying with it for now. I asked then author back then if all the data would be available for download ans he said yes.
Can I download all my collected data from TeslaSpy at any time?
HiHi Jonathanc, please could you send me by private message or mail to [email protected] your teslaspy user?
thanks
