Yes, not working—my favourite feature. Lol.I just updated to 2022.28.2 and it seems to have broken the blinker function on the Teslogic app. Does anyone else have that problem after the update?
@Kate@Teslogic should be fixed the issue with non US speed limits.I updated the app on IOS. The speed is still truncated when over 99 km/h for non US countries. Other issue is that the app used 27% of my battery in just over 60mins CB of usage.
three digits speed limits looks fine now, at least for 100kph on my iphone12. however, I have noticed that resetting current trip wont reset energy meter like before the update showing negative values after a charging session. On track mode still shows power limited at 80% while battery is 89% an 35 celsius degrees, is this a bug or my car is power limited by tesla even with acc boost active?@Kate@Teslogic should be fixed the issue with non US speed limits.
The battery usage is normal because you have the screen always on and brightness maxed out if sunny outside. I always keep my phone plugged in
Please try to update the app, it should solve the problemI just updated to 2022.28.2 and it seems to have broken the blinker function on the Teslogic app. Does anyone else have that problem after the update?
Temperature units in the app correspond to the system of measurement used in the Tesla interface. For the imperial measurement system these are degrees Fahrenheit, for the metric system - degrees Celsius. Do you have temperature units that do not match the interface measurement system? Or do you just want to change it manually?Thank you for the support Kate. One question. How do I change the temperature units for battery temp?
My temperature units set in the system is Fahrenheit, but the app is showing Celsius. I do not have the latest tesla update. Celcius persists after repairing and toggling the system setting. Also I don't quite understand what the map screen is supposed to do. I have not been able to find a way to make it do anything. ThanksTemperature units in the app correspond to the system of measurement used in the Tesla interface. For the imperial measurement system these are degrees Fahrenheit, for the metric system - degrees Celsius. Do you have temperature units that do not match the interface measurement system? Or do you just want to change it manually?
Yes, the update fixed the blinkers. The new "Low Vision" screen is great, I can easily read it without my bifocals. I have only given the update a quick test, tomorrow I should be driving on a motorway do I should be able to give it a more thorough test. I like what I see so far. A couple of comments:Please try to update the app, it should solve the problem
Mine is showing celsius as well, and the app force closes when attempting to tap to change it. This is on app version 1.1.0 (released Sep 18), Android 13.Temperature units in the app correspond to the system of measurement used in the Tesla interface. For the imperial measurement system these are degrees Fahrenheit, for the metric system - degrees Celsius. Do you have temperature units that do not match the interface measurement system? Or do you just want to change it manually?
Many thanks -- these improvements are excellentHi all!
As you already noticed, we released an update. We tried to take into account most of your comments.
Of the big updates:
- Low vision mode with enlarged interface elements and fonts. It will be convenient for drivers with glasses and anyone who wants to increase the comfort for the eyes. Definitely try it out, we use it ourselves!
Other added features:
- We added a settings section, you can find it on the very left screen. What settings are currently available: day/night theme, routing type, screen changing options, low vision mode, font size in notifications, widgets side in navigation, nerd mode.
Bug fixes:
- Calculation of DC charging percentage and average daily consumption to the Car data screen.
- Now the last VIN numbers on the Car data screen are hidden and can be displayed with a tap.
- The ability to choose in which format the time is displayed – 24-hour or AM/PM. You can change it with a tap on the clock.
- The ability to switch light/dark modes manually in the settings section.
- Visualization of adjusting the following distance in autopilot mode.
- Imbalance calculation at the battery info section of the Car data screen.
- The ability to change percentages to kWh or mi with a tap on the battery icon.
- CSV logs are now compatible with MegaLogViewer and datazap.me online service.
- More useful notifications.
All the features that we could not add in this version will be gradually implemented in the next ones. Thanks for letting us know about your wishes and concerns.
- Fixed “share” button bug – now you can share screenshots of your info section.
- Fixed a bug that showed mileage on the odometer in kilometers – now it is displayed in miles for US cars.
- Fixed navigation bugs.
- Fixed speed limit sign for non-US regions.
