I installed the Tasmanian trunk liner which will fold up then you lift the tab so you can access the sub trunk (doesn’t work for the other smaller sub trunk in the pack which is a PTA to access). Only issue is it doesn’t fit quite right when the seats are in recline (the liner is too long and creases as the top which you can see in the picture). Are people experiencing the same issue with the MaxPiders and other liners? Are there any trunk liners available that fit correctly when the seats are in recline and allow easy access to the main rear sub-trunk and second smaller rear sub-trunk?View attachment 651555
