Below is the content of the messages file (with the a whole whack of 1 input overrun(s) messages deleted at the top. There are also messages.0 through messages.4 files, all containing just the repeating overrun message.
May 4 05:48:36 kernel: ttyS1: 1 input overrun(s)
May 4 05:53:13 kernel: ttyS1: 1 input overrun(s)
May 4 06:00:10 kernel: ttyS1: 1 input overrun(s)
May 4 06:01:01 kernel: ttyS1: 1 input overrun(s)
May 4 06:01:50 kernel: ttyS1: 1 input overrun(s)
May 4 06:02:42 kernel: ttyS1: 1 input overrun(s)
May 4 06:02:50 kernel: ttyS1: 1 input overrun(s)
May 4 06:03:30 kernel: ttyS1: 1 input overrun(s)
May 4 06:07:01 kernel: ttyS1: 1 input overrun(s)
May 4 06:07:52 kernel: ttyS1: 1 input overrun(s)
May 4 06:10:08 kernel: ttyS1: 1 input overrun(s)
May 4 06:11:09 kernel: ttyS1: 1 input overrun(s)
May 4 06:14:50 kernel: ttyS1: 1 input overrun(s)
May 4 06:18:57 kernel: ttyS1: 1 input overrun(s)
May 4 06:28:41 kernel: ttyS1: 1 input overrun(s)
May 4 06:33:38 kernel: ttyS1: 1 input overrun(s)
May 4 06:36:02 kernel: ttyS1: 1 input overrun(s)
May 4 06:45:38 kernel: ttyS1: 1 input overrun(s)
May 4 06:45:51 kernel: oom-killer: gfp_mask=0x4d0
May 4 06:45:51 kernel: DMA per-cpu:
May 4 06:45:51 kernel: cpu 0 hot: low 4, high 12, batch 2
May 4 06:45:51 kernel: cpu 0 cold: low 0, high 4, batch 2
May 4 06:45:51 kernel: Normal per-cpu: empty
May 4 06:45:51 kernel: HighMem per-cpu: empty
May 4 06:45:51 kernel: Free pages: 792kB (0kB HighMem)
May 4 06:45:51 kernel: Active:159 inactive:119 dirty:0 writeback:0 unstable:0 free:198 slab:0 mapped:0 pagetables:0
May 4 06:45:51 kernel: DMA free:792kB min:724kB low:904kB high:1084kB active:636kB inactive:476kB present:32768kB pages_scanned:1349 all_unreclaimable? yes
May 4 06:45:51 kernel: lowmem_reserve[]: 0 0 0
May 4 06:45:51 kernel: Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
May 4 06:45:51 kernel: HighMem free:0kB min:128kB low:160kB high:192kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
May 4 06:45:52 kernel: DMA: 56*4kB 1*8kB 1*16kB 1*32kB 0*64kB 0*128kB 0*256kB 1*512kB 0*1024kB 0*2048kB 0*4096kB = 792kB
May 4 06:45:52 kernel: Normal: empty
May 4 06:45:52 kernel: HighMem: empty
May 4 06:45:52 kernel: Out of Memory: Killed process 249 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 250 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 251 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 252 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 253 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 254 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 255 (vms).
May 4 06:45:52 kernel: Out of Memory: Killed process 256 (vms).
May 4 06:45:53 kernel: Out of Memory: Killed process 257 (vms).
May 4 06:45:53 kernel: Out of Memory: Killed process 258 (vms).
May 4 06:45:53 kernel: Out of Memory: Killed process 259 (vms).
May 4 06:45:53 kernel: Out of Memory: Killed process 260 (vms).
May 4 06:45:53 kernel: Out of Memory: Killed process 261 (vms).
May 4 06:45:54 kernel: Out of Memory: Killed process 262 (vms).
May 4 06:45:54 kernel: Out of Memory: Killed process 263 (vms).
May 4 06:45:54 kernel: Out of Memory: Killed process 264 (vms).
May 4 06:45:55 kernel: Out of Memory: Killed process 265 (vms).
May 4 06:46:48 syslogd started: BusyBox v1.00 (2011.04.26-01:24+0000)
May 4 06:46:48 init: ^MStarting pid 131, console /dev/console: '/sbin/ifconfig'
May 4 06:46:52 init: ^MStarting pid 135, console /dev/console: '/bin/mv'
May 4 06:46:53 kernel: klogd started: BusyBox v1.00 (2011.04.26-01:24+0000)
May 4 06:46:53 kernel: Linux version 2.6.11.8-2.1.0 (
[email protected]) (gcc version 3.4.3) #296 Mon Mar 23 13:50:14 PDT 2009
May 4 06:46:53 kernel: CPU: Philips-LPC2294 [fff00000] (ARMv3)
May 4 06:46:53 kernel: Machine: LPC2294
May 4 06:46:53 kernel: On node 0 totalpages: 8192
May 4 06:46:53 kernel: DMA zone: 8192 pages, LIFO batch:2
May 4 06:46:53 kernel: Normal zone: 0 pages, LIFO batch:1
May 4 06:46:54 kernel: HighMem zone: 0 pages, LIFO batch:1
May 4 06:46:54 kernel: Built 1 zonelists
May 4 06:46:54 kernel: Kernel command line: panic=5 console=can3 initrd=yes
May 4 06:46:54 kernel: PID hash table entries: 256 (order: 8, 4096 bytes)
May 4 06:46:54 kernel: Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
May 4 06:46:54 kernel: Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
May 4 06:46:54 kernel: Memory: 32MB = 32MB total
May 4 06:46:54 kernel: Memory: 29888KB available (1273K code, 292K data, 8K init)
May 4 06:46:55 kernel: Calibrating delay loop... 4.23 BogoMIPS (lpj=21184)
May 4 06:46:56 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
May 4 06:46:56 kernel: checking if image is initramfs... it is
May 4 06:46:56 kernel: Freeing initrd memory: 884K
May 4 06:46:56 kernel: NET: Registered protocol family 16
May 4 06:46:56 kernel: SCSI subsystem initialized
May 4 06:46:56 kernel: usbcore: registered new driver usbfs
May 4 06:46:56 kernel: usbcore: registered new driver hub
May 4 06:46:56 kernel: Real Time Clock Driver v1.12
May 4 06:46:56 kernel: LPC2xxx Watchdog Driver
May 4 06:46:56 kernel: LPC2xxx ADC Driver
May 4 06:46:56 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
May 4 06:46:56 kernel: ttyS0 at MMIO 0x0 (irq = 6) is a 16550A
May 4 06:46:57 kernel: ttyS1 at MMIO 0x0 (irq = 7) is a 16550A
May 4 06:46:57 kernel: io scheduler noop registered
May 4 06:46:57 kernel: io scheduler anticipatory registered
May 4 06:46:57 kernel: io scheduler deadline registered
May 4 06:46:57 kernel: io scheduler cfq registered
May 4 06:46:57 kernel: RAMDISK driver initialized: 1 RAM disks of 4096K size 1024 blocksize
May 4 06:46:57 kernel: PPP generic driver version 2.4.2
May 4 06:46:57 kernel: PPP Deflate Compression module registered
May 4 06:46:57 kernel: tun: Universal TUN/TAP device driver, 1.6
May 4 06:46:57 kernel: tun: (C) 1999-2004 Max Krasnyansky <
[email protected]>
May 4 06:46:58 kernel: NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit)
May 4 06:46:58 kernel: Creating 1 MTD partitions on "NAND 512MiB 3,3V 8-bit":
May 4 06:46:58 kernel: 0x00000000-0x20000000 : "NAND filesystem"
May 4 06:46:58 kernel: sl811: driver sl811-hcd, 15 Dec 2004
May 4 06:46:58 kernel: sl811: SL811HS v1.5, irq 16
May 4 06:46:58 kernel: sl811-hcd sl811-hcd: new USB bus registered, assigned bus number 1
May 4 06:46:58 kernel: hub 1-0:1.0: USB hub found
May 4 06:46:58 kernel: hub 1-0:1.0: 1 port detected
May 4 06:46:58 kernel: Initializing USB Mass Storage driver...
May 4 06:46:58 kernel: usbcore: registered new driver usb-storage
May 4 06:46:58 kernel: USB Mass Storage support registered.
May 4 06:46:58 kernel: usbcore: registered new driver usbserial
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI SIO
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI 8U232AM Compatible
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI FT232BM Compatible
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI FT2232C Compatible
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for USB-UIRT Infrared Tranceiver
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for Home-Electronics TIRA-1 IR Transceiver
May 4 06:46:59 kernel: usbcore: registered new driver ftdi_sio
May 4 06:46:59 kernel: drivers/usb/serial/ftdi_sio.c: v1.4.1:USB FTDI Serial Converters Driver
May 4 06:46:59 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303
May 4 06:47:00 kernel: usbcore: registered new driver pl2303
May 4 06:47:00 kernel: drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.12
May 4 06:47:00 kernel: i2c /dev entries driver
May 4 06:47:00 kernel: LPC2xxx I2C Driver
May 4 06:47:00 kernel: LPC2xxx CAN Driver
May 4 06:47:00 kernel: LPC2xxx CAN Console Driver
May 4 06:47:00 kernel: NET: Registered protocol family 2
May 4 06:47:00 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
May 4 06:47:00 kernel: TCP established hash table entries: 2048 (order: 2, 16384 bytes)
May 4 06:47:00 kernel: TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
May 4 06:47:02 kernel: TCP: Hash tables configured (established 2048 bind 2048)
May 4 06:47:02 kernel: NET: Registered protocol family 1
May 4 06:47:02 kernel: NET: Registered protocol family 17
May 4 06:47:03 init: ^MStarting pid 139, console /dev/console: '/bin/iptables'
May 4 06:47:05 init: ^MStarting pid 142, console /dev/console: '/bin/iptables'
May 4 06:47:09 init: ^MStarting pid 144, console /dev/null: '/bin/watchdog'
May 4 06:47:09 init: ^MStarting pid 145, console /dev/null: '/bin/inetd'
May 4 06:47:09 init: ^MStarting pid 146, console /dev/null: '/bin/obd'
May 4 06:47:09 init: ^MStarting pid 147, console /dev/null: '/bin/pppconnect'
May 4 06:47:09 init: ^MStarting pid 148, console /dev/null: '/bin/logd'
May 4 06:47:10 init: ^MStarting pid 149, console /dev/console: '/bin/minder'
May 4 06:47:16 syslog: VMS: VMS restarted - version 15.1.0
May 4 06:47:16 kernel: serial8250: too much work for irq7
May 4 06:47:21 syslog: VMS: Watchdog reset 1 4291
May 7 23:05:34 kernel: usb 1-1: new full speed USB device using sl811-hcd and address 2
May 7 23:05:34 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
May 7 23:05:34 kernel: usb-storage: device found at 2
May 7 23:05:34 kernel: usb-storage: waiting for device to settle before scanning
May 7 23:05:40 kernel: Vendor: USB Model: Flash Disk Rev: 1100
May 7 23:05:40 kernel: Type: Direct-Access ANSI SCSI revision: 04
May 7 23:05:40 kernel: SCSI device sda: 3915776 512-byte hdwr sectors (2005 MB)
May 7 23:05:40 kernel: sda: assuming Write Enabled
May 7 23:05:40 kernel: sda: assuming drive cache: write through
May 7 23:05:40 kernel: sda1
May 7 23:05:40 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
May 7 23:05:41 kernel: usb-storage: device scan complete
May 7 23:11:03 kernel: ttyS1: 1 input overrun(s)
May 7 23:11:42 kernel: ttyS1: 1 input overrun(s)
May 7 23:13:19 kernel: ttyS1: 1 input overrun(s)
