Did you install your own wires and breaker or did you get them installed?
I suppose that the correct wires have been used,
however if you want to check if your wires are the correct size for the load
you need to determine
which wires have been used and measure
the length of the line.
I would recommend then using a
Voltage drop calculator (
Excel tool file ) to determine if the line will not get too much heat losses.
It would be great, you are right, to plug an EV such as a Tesla,
because you could read the
delivered Voltage when charging with
different Amp values.
This will give you idea of the real load capacity of your installation and
check for voltage drop.
For high intensity, I believe that you need to have a
10 to 20 minutes load to really test your system for possible overheating.
If you have an
electrical range oven, then you could use it instead of using an EV.
Then with a
Voltmeter, and an
Amperage probe (in general commercial voltmeters cannot measure more that 5 to 10 Amp)
you could make similar measurements.
Note: Do you really need to charge at 50 Amp (40 Amp 80% nominal) ? For most users a
30 Amp (24 A nominal) will be sufficient,
as you will get about
20 miles/hour or about
200 miles after a 10 hours night charge.
I have a Model 3 LR and a 30 Amp give me about 10% of charge per hour.
