That "Obstacle Detected" might be your other door!
Discussion in 'Model X' started by Desmo999, Jan 11, 2017.
Tags:
  1. Desmo999
    Desmo999 Member
    Redwood City, CA
    I've had door sensors replaced 3 times now on my Model X (April 2016 delivery), but here's a quick warning for other owners to avoid more serious damage...
    I had a passenger closing the rear door at the same time as the front and the doors stopped with an "Obstacle Detected" warning on the touch screen. I told them it's the bad sensors again and to ignore it and just press the button again to open/close the door...but my passenger was standing outside and said "it's not a sensor - the doors actually hit." Otherwise I wouldn't have known from the driver seat.
    Only shot one video of this for Tesla Service and will open/close one at a time to prevent more damage, but look out and don't assume it's just the usual bad sensors:
    • Informative x 3
  2. trmmcd
    trmmcd Member
    Arlington, MA
    I had a similar issue with my car - not quite as bad as yours - but almost. I was a May delivery. The SC was able to make some door adjustments and they also changed the pinch sensors on the doors - apparently there is a new part which doesn't protrude as much. I don't however recall the sensors alerting - but I think we typically experienced this on door opening when everyone was getting out of the car at the same time. Even after the fix though - my wife still won't allow both doors to be operated at the same time :).
  3. DriverOne
    DriverOne Supporting Member
    Austin, TX
    Wow. Had not expected that. Almost bound to happen eventually :( Not sure what to tell passengers now.
  4. brkaus
    brkaus Well-Known Member
    Austin, TX
    Wow. Sounds like a software adjustment is required to add some mutual exclusivity to the door operations - at least at specific parts of the closing process.
  5. andrewket
    andrewket Well-Known Member
    We had this problem as well. It scratched the paint on the front door. The tolerances are apparently very tight.
  6. PedanticOne
    PedanticOne MyTesla Refresh Champion
    Bay Area, CA
    Found same issue called out in this thread, which is linked from the FAQ.
  7. Desmo999
    Desmo999 Member
    Redwood City, CA
    This was my first reaction... Feels like an easy one to slow the FWD until the front door clears. Not as cool looking as "everything closing as once", but would have prevented another trip to the body shop. :(
