The 12 Volt Battery
smorgasbord
3,193
5,059
SF Bay Area
There are a couple discussions dancing around the 12 volt system in Roadsters:
http://www.teslamotorsclub.com/showthread.php/4849-12-volt-accessories
http://www.teslamotorsclub.com/showthread.php/4560-Voluntary-fix-offered-for-Roadster-models-2-0-and-2-5?highlight=12+volt+battery
However, I couldn't find a lot of specifics on the 12 volt battery.
1) Is it just an AGM battery?
2) How/when is it charged?
3) Can anyone categorically state which systems it drives and/or acts as a buffer on?
4) Has anyone had it fail? If so, what happens?
dsm363
Roadster + Sig Model S
May 17, 2009
18,278
151
Nevada
I can answer the last one. Mine went out recently (got car Dec 2010). Am waiting for it to get replaced. I have to use physical key to open my door.
markwj
Moderator, Asia Pacific
Apr 10, 2011
4,584
1,180
Hong Kong
It is a little lead-acid motorcycle-style 12V battery.
It is kept topped-up by the main ESS.
It drives the car's emergency systems. Things like brake lights, hazard warnings, alarm system, etc.
If it fails, VDS will give a warning and car must be manually unlocked.
I've no idea if car can be driven if it has failed. Some reports say yes, but it may depends on the degree of failure - 0V is obviously a failure, but what about 1V, 5V or 10V?
ggr
Expert in Dunning-Kruger Effect!
Mar 24, 2011
6,972
27,477
San Diego, CA
Yes. I'm on my third, as of last week. Everything works fine once you actually turn on the car (since that uses the main battery).
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Here's what the battery looks like:
markwj
Apr 10, 2011
4,584
1,180
Hong Kong
By the way, I can personally attest that the other way round doesn't work - if the main ESS goes out and little 12V is fine, brake lights work but car can't be driven :)
W.Petefish
1,060
11
I'm wondering if the 12v battery could be moved to the trunk. I think that might be easier to replace and it could be made bigger so that it doesn't need to be replaced as often. Only downside would be, you'd lose some trunk space.
DRM
Roadster #512
Just had mine replaced yesterday; it went out last week. The key fob didn't work, but rather than using the manual key i was told to open the charge-port door -- it engages the high-voltage system which then provides 12v. It was a bit wierd opening the charge port door b/f the keyfob would work but wasn't really a problem. The car otherwise operates as normal. The battery itself is a smallish motorcycle-sized battery.
//dan.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
^ Isn't opening the charge port door just waking the car up? In that case it would also be possible to open the car still with OVMS, circumventing any 12v battery issue?
vfx
14,790
40
CA CA
My first thought is they did a firmware change.
markwj
Apr 10, 2011
4,584
1,180
Hong Kong
Aw, crap, mine just went 'fault' this morning.
Car still operates just fine - just getting a warning every time I get in to it.
markwj
Apr 10, 2011
4,584
1,180
Hong Kong
Can you unlock the doors with the key fob? Mine finally got fixed.
Haven't tried - I've been using OVMS to lock/unlock as I know that works even without a 12V battery working :)
I'm told that the car tries to use the 12V battery to unlock the doors, but if there is insufficient power then the car issues the alert to the VDS then wakes up the main ESS and 12V converter (hear the little coolant circulation pump working) and uses that to power the door unlock. Opening charge port door, or just pressing door handle, does the same thing - but may take a second or two to wake up. Pretty much aligns with everything I learned doing OVMS.
tetsuos
HK #488 (2.5)
Apr 10, 2011
32
0
Hong Kong
Mine failed recently. Unlocking the doors with the fob took a few extra presses (and smaller range), and following unlock, the door handles did not release the door latch until the car had booted up (around 5-10 seconds after unlock).
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Mine is at 24 months... no problems yet. Will probably die when the weather gets cold. In my experience these types of batteries under moderate usage last a few years.
+1 - I'm at 2 years since delivery. But then again I don't use the car that often. Service will be in about 2 weeks.
How difficult is it to access the battery? The picture is good - I just don't know how much it took to access it.
