The Canadian Immobilizer
Discussion in 'Canada' started by Prime Mover, Dec 8, 2012.
Tags:
  1. Prime Mover
    Prime Mover R Sport #1029; S #2117
    Toronto, Canada
    #1 Prime Mover, Dec 8, 2012
    "Immobilizer" sure sounds imposing!
    This device, to help keep the Model S from being stolen, is a mandatory requirement by Transport Canada. On the Roadster, it was implemented by requiring the middle button on the key fob to be pressed after starting the car.
    One of the great features of the Model S is that, with the key fob in your pocket, the car will open and after you sit in the driver's seat, it is ready to go (no Start button required).
    Are we in Canada going to have to press some button on the key fob to deactivate the Immobilzer or does the key fob automatically authenticate itself to the car?
    If we have to do some manual step, that would be a nuisance. Does anyone know if we will have to do something to "start" our Canadian cars?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    #2 Doug_G, Dec 8, 2012
    Here are the requirements: http://www.tc.gc.ca/media/documents/roadsafety/1140rev1_e.pdf
    I can see nothing in the specification that would require a manual key press.
    Found additional referenced information Motor Vehicle Safety Regulations section 114.
    The main standard document appears to be CAN/ULC-S338-98. Usually this sort of standard you have to pay for. I did some web searching and it appears the requirement is that some sort of "tag" device be present in the vehicle and it meets certain technical standards.
    Looks like no button presses required. But we'll see.
  3. Jaff
    Jaff Active Member
    Grimsby, Canada
    The Canadian Immobilizer ...he's a pro wrestler, ain't he? :wink::biggrin:
  4. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    Perhaps this is one of the things, or THE thing that was holding up TC approval. Maybe they just had to educate TC to their new security paradigm, and satisfy TC that they were meeting the requirements, perhaps in an unconventional way.
    On the other hand, I have learned to live with Roadster scheme, and it does not bug me anymore, so I can get used to something new with the Model S, if required.
  5. inottawa
    inottawa Member
    Ottawa, ON, Canada
  6. Doug_G
    Ottawa, Canada
    Licensed in the USA. You can drive over the border...
  7. inottawa
    inottawa Member
    Ottawa, ON, Canada
    of course.. I didn't bother looking at the plate.
  8. znino
    znino Member
    Montreal, Canada
    I have become used to the Roadster scheme too but as Prime Mover said, one of the great things about the Model S is having no key and no button to press. you can have the FOB in your coat pocket. If you have to take it out to press something before driving off, it's no longer a convenience over a key and worse than most keyless start systems out there (If you have to press the fob, rather than a button in the car). With the Roadster you need the key anyway so the extra button push is no big deal as you have already pulled the key out of your pocket and have it in hand after inserting in the ignition.
  9. Jaff
    Jaff Active Member
    Grimsby, Canada
    The grey Model S at the Toronto store has a Cali plate on it...
  10. mknox
    mknox Well-Known Member
    Toronto, ON
    The web site has always shown Model S (both US and Canada) as having "Anti-theft alarm and immobilizer system". What is the difference with the Canadian immobilizer and why wouldn't Tesla just use the same design for both US and Canada?
  11. Doug_G
    Ottawa, Canada
    Apparently the standard Canada is using has some extra requirements that the original immobilizer did not meet. Might be as simple as number of code or as complex as rolling code logic. Not sure; you'd have to purchase the relevant standards document to suss it out.
  12. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    So, now that people have their cars, what's the word on the immobilizer? Same operation as US cars?
  13. Doug_G
    Ottawa, Canada
    Works the same. Just more secure.
  14. Mayhemm
    Thought so. Good to have it confirmed.
    Thanks, Doug!
