The correct method to escape from the falcon wing door of Model X.
Discussion in 'Model X' started by Xiao ma ge, Apr 25, 2017.
  1. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    how do you calibrate the door? How did you know it needed calibration?
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    How powerful are the door motors?
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Wasn't there a post where the doors had an issue opening when the car wasn't level? I'm not sure the motors able to handle too much extra weight....
  4. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    The X will tell you on the display to press and hold for so many seconds.
  5. muleferg
    Posted by Ohmman
    Falcon Wing Door Calibration
    Take the vehicle outdoors where there’s nothing in range of the FWD (and probably no overhead cache - that is, the display allows you to fully open the doors on one touch.) Hold the physical door switch inside the vehicle until door is all the way open. Next, hold the physical door switch down until the door is all the way closed. The door should be recalibrated at this point.
  6. Jrogville
    Jrogville Member
    High Springs, Florida
    At the very least, I wish that ball were larger and red to stand out more.
  7. tezzla
    tezzla Member
    SoCal
    Very helpful video, it's one thing to read about and another to actually see it. Thanks.
