This is a question for all you Sandy Munro-types out there: if I wanted to build exactly one Cybertruck, based roughly on the dimensions given at the unveiling, how much would it cost? I've seen a few different builds online. Aside from not listing the material and labor costs, they're also either gas-powered or miniatures. I'm talking about a 1:1 BEV replica of what Elon has been hooning around LA. Let's further assume that I have an extra Model X sitting around that I can cannibalize for this project, but no technical know-how or access to a friend with a machine or welding shop. And this is purely a thought experiment, so no need for the "why don't you just wait until December of 2021?" comments. I'm just curious.
If you wanna do a crappy knockoff and are happy to destroy the X to do it, and you are good at metalwork. If you expect to do a one for one, you won't get to cannibalize the X too much, different ground clearance, axel distances, and width. What are you expecting?
I guess that's true. So maybe it'd need to be the size of a mid-size pick up. Let's call it 75% instead of 1:1
Yes. You could indeed put an array of 2 long by 4 wide model 3 battery modules. You could put the short ones together and long ones together to make a super 150kw skateboard. Or just use a P100D battery and drivetrain and suffer with less range but clearly enough power. Personally if I was doing a one off, a wrecked S/X with 100kwh battery would be the choice as it would be cheap and could be done with less engineering.
