I posted these instructions for setting up an Android phone. You don't need the app on or the screen on in order to use the phone key to unlock your car.Question: Is there a definitive thread on how to set up phone key?
We have a 2018 model 3 and a 2021 model Y. Both bought new. We’ve used numerous iPhones over the years from iPhone 7 to now iPhone 13 pro. For the past 4 years, I always have the app running. Never swiped it away. Bluetooth always on. Phone in front pocket. Etc etc. Basically we’ve done everything we could. Everything people have mentioned here.
I’d say the phone key works 80%. I still cannot find out what the culprit is. All phone seems to work the same. We have less of this problem with the model 3 than the model Y.
The routine is… I approach the car. Lift the door handle. Nothing. Sentry mode kicks in and recording. Frustrated, I take my phone out. Take on the screws (does not need to unlock). Then doors open. Sometimes I could go a week without any issues. Sometimes it happens to me 5 times a day.
Yes it sounds like it’s a problem with the phone. But 6 different phones later, no real improvement. I drive the model 3 for 3 years before switching to the Y, and wife took over the 3. She RARELY has issues with unable to open door with phone key. But I have a lot of issues with the Y. I say it’s more of a car issue.
It’s not a car issue. Ever since Apple kept doing battery saving software updates it gets worse. As you said, when you take your phone out it works. That’s the lift to turn on feature in the iPhone software.We have a 2018 model 3 and a 2021 model Y. Both bought new. We’ve used numerous iPhones over the years from iPhone 7 to now iPhone 13 pro. For the past 4 years, I always have the app running. Never swiped it away. Bluetooth always on. Phone in front pocket. Etc etc. Basically we’ve done everything we could. Everything people have mentioned here.
Is it possible to disable the phone key temporarily, say at night?
The Bluetooth range is excellent and the Tesla app will regularly say connected when I'm quite some distance away in my house. The only suggestion I've found online is to disable Bluetooth. But that then renders my smart watch and headphones useless.
Unless he continues to check his app over and over waking the car. LolThat shouldn't be cause for concern. The car will sleep normally and remain locked.
Good question.Is it possible to disable the phone key temporarily, say at night?
Hi, it's definitely the phone key connected under Security as you say. Also the persistent notification changes.Good question.
Does the phone app say it's connected as a phone key (under "Security"), or is it connected only via the Internet?
Via the Internet, the phone can remotely operate its climate controls, windows, lock/unlock, etc. but pulling a door handle won't unlock the car.
You could also test it by leaving the phone in the house then pulling the car door handle.
So to check. After 5 minutes of the car being stationary, it goes into sleep mode. Unless I actually open the app, the car won't unlock even though the app key has connected over Bluetooth. Have I understood this correctly?
Oops I meant to type “tap on the screen”.Frustrated, I take my phone out. Take on the screws (does not need to unlock). Then doors open.
iPhone. In settings, display and brightness, enable raise to wake. Then you won’t have to touch the screen.Oops I meant to type “tap on the screen”.
The fact that I need to tap my screen to wake the phone and unlock the car is silly. Yes that sounds like it’s the phone’s issue. But I cannot explain why it happened with the Y wayyyy more often than the 3. The 3 is 3 years older than the Y.
Always been on.iPhone. In settings, display and brightness, enable raise to wake. Then you won’t have to touch the screen.
I'm happy to report that I was right the first time. Even when the app is running in the background, I'm around 80% chance that it works well. 1 in 5 chance I'll be waiting by my door for at least 20 seconds or I have to go into the app and manually unlock the car.Did I just turn into the grandpa that needs the kids to do the input on the TV thing? I just figured the app was always on... If that's all I was missing for the past 4 years of driving a Tesla, I will delete this thread out of pure embarrassment. lol
You can swap away. When you restart the phone this notification don't come back until you start the app.Is it only a recent change that we can "swipe" away the Android notification? I always thought this was a persistent notification but I freaked out when I swiped it away the other day. Obviously I can relaunch the app, but I'm surprised it allowed me to do that. I thought the idea of a persistent notification was to force apps that need to run in the background to be noticed by users. Based on that I thought you weren't allowed to swipe away and the only way to avoid the notification was to disable that notification specifically.
I think this may be Android versino dependent, but I think Android 13 doesn't really require apps to display a persistent notification anymore. when you swipe down the notification bar fully where it shows the Quick Settings tiles, I can see X apps active:You can swap away. When you restart the phone this notification don't come back until you start the app.
