I corrected my original post. We install pad mount (sit on the ground) transformers as large as 100 kVA. The pad and other infrastructure is sized to accommodate a 167 kVA transformer.
Which transformer would that be exactly, distribution or substation? What I don't know much about are the details of the hierarchy of electrical distribution. How much expansion is possible before major changes are needed. But even swapping out transformers is not cheap and if that ends up being required en masse, I expect the utility will want to recoup that cost. I know plenty of other stuff ends up on my electric bills.
CooPs do not follow the same rules as corporations. I believe each customer is a member of the coop and somehow shares in the ownership.
The extent of "ownership" is they return profits to us in the form of a credit on the bill, we receive a monthly magazine (which I believe is an official communication as I've tried to get them to not send it and they can't/won't unsubscribe me) and an annual election of I assume a board.
The 72 kW was another mistake. Sorry should do more proofreading. Corporations are not intrinsically evil. But they can be corrupted.
I'm not so sure. I even bought a cell phone from a company that had printed on the package "no evil" indicating they didn't pass on any of the usual fees and such. Then some time later they started charging an E911 fee. lol
As I mentioned, my coop has many issues where they just stiff arm you when you try to deal with them. I only got a satisfactory response when I contacted the state regulatory office. Yes, even a coop can be "evil".
I think we are going to be OK if the utility utilizes some kind of TLM (Transformer Load Management).
qu'est-ce que c'est TLM?
The rest of the distribution grid is built for expansion. Look around you and see if you think the load has increased in the past 30 years? How has the CooP managed that growth? Have they added more transformers to existing substations? Have they replaced them with larger ones? Have they built more substations? Have the overhead lines been changed from single phase to three phase? Have the overhead lines been replaced with larger ones?
My one house is on the edge of a commercial area. Very significant growth on that side of the street and major changes to the power distribution. My side street has seen nothing change, but then there is no real growth in 50 years other than one business built. It is not clear what changed to accommodate the business. My power comes from pole mounted transformer. I can't say if that was upgraded or not.
The other house was built 30 years ago on a building lot with several building lots next to it which I'm sure were all planned for and now built up. So what happens if half of these houses get EVs and start charging every other night at 11 kW? What happens when every one of the half with EVs charge at the same evening (like a Friday night) or the holiday weekend when they have a party and two or three other EVs show up and they get charged continuously for a day all the while hot tubs are being used? That reminds me that I need to get my hot tub going.
Typically distribution grids are built with expansion in mind because areas are prone to growth.
I get that, but I'm not sure they are sized adequately for the sort of growth expected at the time they were built now that EV charging will be on top of that.
Would you say that the utilities are not going to need to give any real consideration to EV charging going forward? The distribution grid will be expanded seamlessly through the normal processes? That's the part I can't picture given the magnitude of the added loads and the rapidity of the expansion. It will be 10 years before we see significant growth in the ownership of EVs, but somewhere in this path the expansion will be much more rapid than it is now as EV ownership approaches 50% of all personal vehicles. Also keep in mind that many homes will have two or three EVs.
