My model 3 suddenly stopped working no matter where I push….it clicks and the dashcam records but no sound. Any idea how much this will cost if I need to replace the steering wheel (out of warranty)?
Did you see where the horn is located? I’d like to replace my OEM horns with something much betterI just had my horn assembly replaced free of charge under a warranty repair by the mobile service team. It looks like it would have cost about $130 according to the original estimate had I been on the hook for the bill. It took about 20
minutes to replace. The tech told me that they had quite a bit of these go bad in the early builds of the model 3.
I can't tell you how to replace them. But, they are located in front of the driver's side front wheel.Can anyone tell me where the horns are and how to replace them?
I just received a quote for $442 to replace the horn. I think this quote is a little inflated. I may attempt to replace on my own.I had mine replaced recently because the low tone horn was out. I was quoted $133 I think.
Previously the horn started working after I had the heater running on high for about 10 minutes. So I decided with a quote to invest 10 minutes of my time to dig in further into the issue. I removed three clips of the wheel liner on the front left wheel to get partial access to the horn and ran a heat gun on low setting over the horns for about 1 minute and the horns (low and high tone) are working perfectly. So there is probably just some humidity in the connectors. When the weather improves, I will remove the wheel, liner and clean the connectors. Probably will take about 20 minutes. So for others that the horn doesn't work with the app or the steering wheel this may be something to try before shelling out a significant amount of money for a minor issue.I just received a quote for $442 to replace the horn. I think this quote is a little inflated. I may attempt to replace on my own.
