The Junior Programmers are at it again
mrElbe
1,714
1,133
Stouffville, ON Canada
It used to be that when I crossed the border into USA and left my Units in metric, that US MPH speed limit signs were automatically translated to km/h. For instance a 50 MPH sign would display on the instrument panel as 80 km/h.
My Canadian Model S ( AP1 ) is currently at firmware level 17.14.23
Last Thursday I entered the US and the MPH signs did not translate while Units are set in metric mode. It was as if the car was still in Canada.
Switching to miles mode translated the 50 MPH sign to 30 MPH in the instrument panel display. WTF!
I talked to Tela assistance and the Technician was as perplexed as I was. He asked me to re-boot the main screen but same result. He promised to open up an "Incident".
Also during my travels in the US ( NY, PA, MD ) I noticed that speed limit signs on Interstates were not recognized. On secondary roads they were seen but interpreted wrong.
Back in Canada today, everything worked as intended.
How could these programmers screw up something that worked until now so badly. Have they no cognisance that Canada exists and that Canadian owners might travel to the USA?
Absolutely no field testing and quality control.
Autopilot seemed to know the correct speed limits and worked well. So it looks like that code is independent of the instrument panel display.
RiverBrick
2,504
1,713
Mount Washington Valley
Have they no cognisance that Canada exists ..?
It's not out of the realm of possibility. :) Do you still get stuck with bars as the unit for tire pressure?
Also, Quebec might be the only place in the World with > 2,000 Teslas and no interface or navigation available in the predominant native language. Considering a French interface has been available to Europeans for over two years, Tesla is not overly in a hurry to adapt to the Canadian market.
Reactions: Imafrog and Falkirk
Hugh Mannity
Mediocre Member
Jul 31, 2014
1,349
804
Calgary, AB
sure....
And how tall are you?
What do you weigh?
....thought so......;)
Ha ha actually my wife has been a good influence. She's from Japan and the feet and pounds thing drives her crazy. She learnt me up on using kg and metre and I'm getting used to it. Area though? Yeah square metres means nothing to me ...... yet .....
ShockOnT
Jun 26, 2016
3,294
3,007
Sydney
Switch to metric, stay in the Paris Accord, get rid of the guns, lose some weight, open just one of a restaurant, use smaller cups, and for Gods sake I think we have enough episodes of NCIS.
And snap to it! I've had enough of this dilly-dallying. I mean it, don't make me come over there or I'll put you all in the naughty corner.
Regards, ShockOnT from Australia (England's naughty corner)
McRat
5,771
5,414
LA
The real problem here is the Americans are using the Imperial system.
Switch to metric already! Embrace the rest of the world; it's not so bad after you get used to it. :cool:
We did switch. Kinda. I think it was 1975'ish. Military and medical, and most aerospace blueprints are in mm. The metric system was taught in schools for the changeover. Our scientific and engineering equipment is normally metric or dual-mode. Our cars have metric fasteners. Chemistry and science is always done in metric. Illegal drugs are even in metric.
Now if we could just convince Americans we switched over. :D
But... WTF is it with Excel and other apps that think angles should be measured in radians???? WTF is that about??? :mad:
Sorry, but the earth coordinates, a 30°, 45°, 90° angle exists not only in nature, but logically since 360° is easy to do in base10 math, meshes well with hours, and is divisible by everything but the kitchen sink.
SHOOT ANYBODY ON SIGHT WHO USES RADIANS IN THE REAL WORLD. :mad:
Reactions: mrElbe
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Reactions: dasRad and mrElbe
DMC-Orangeville
85D and John Deere 5100E
Feb 14, 2015
928
1,124
Orangeville ON Canada
As mentioned above....Canada is fully metric....
Except:
Height of humans/weight of humans
Lumber (2X4) (4X8 sheet of plywood, drywall)
Pipe (Electrical is 10' length, plumbing 12' length)
Diameter of almost everything (1/2" etc)
Real estate (3000 sq ft house on 2 acres)
...and I know EXACTLY what 63 degree feels like. I have to guess at what 17 degree C is....
Correction....Canada is not fully metric
Reactions: cwave1 and X Fan
dasRad
234
73
Kelowna, BC, Canada
and,
S = rθ
Good luck with arc lengths using degrees. Just how far is it around a circle?
but, I'll grant you that most people don't need to work with the nth roots of 1. That might be overly complex. :)
Drone Flyer
1,127
258
Canada
Except:
The premier Football League which is in Canada, still uses Yards and not metres!
CFL!
Reactions: DMC-Orangeville
Drone Flyer
1,127
258
Canada
I like NCIS especially the newer incarnation, NCIS New Orleans! Probably better than most of the garbage we see nightly during the Fall and Winter! I loved "JAG" the forerunner of the NCIS chain.
Cosmacelf
8,292
19,559
San Diego
Metric has its place, but ... a 1 degree Celsius temperature difference in your home thermostat is too big a jump, which is why digital ones allow you to set to 1/2 degree increments, whereas a degree Fahrenheit is just the right amount. Volume measurements are easily understood in terms of pints, quarts and gallons. In Canada, when you buy baggies to store food in, they are like 324 ml, 534 ml, etc. Weight is messed up as well. An ounce is a useful measure of weight, whereas a gram is way too small for anything common. And then a kilogram is pretty big with nothing in common useage between a gram and a kilogram.
Metric should stay with scientists where it makes a lot of sense, but for us ordinary non-scientists, imperial measures are much more useful.
