Ordered in late June, just installed last month. Components were:
- Panels: Hanwha Q.Cell Q.PEAK DUO-G6+/SC 340 x 36
- Inverter: SolarEdge Technologies SE11400H-US000BSC4
- Gateway: Tesla Solar Gateway GWY20 (aka Neo Gateway, aka black box)
Thank you for sharing!
How do you know the exact model of your inverters? Tesla sent us a sheet with like 5 model # on it!
Also, is GWY20 the box that looks like a little Powerwall? What other ones are out there and do you know the difference?
Thank you again!
Your exact model will depend on your system size, for the most part. My system size is 12.24 kW DC, so that's paired with the 11.4 kW AC inverter. In general DC/AC should be something like 1.2 or less to avoid clipping.
There is some variance on whether you get the model with the LCD screen or the one that gets set up via WiFi, but that seems down to what Tesla has in stock in your area.
Are you ordering Powerwalls? If yes, then your Gateway will be the white box that looks like a mini Powerwall. If no, then you're given a small black box that hooks into your router. I don't have Powerwalls, so that black box is all I have. Looks like this:
Thank you guys... I'll try to found out the exact inverter model, but yes, no Powerwall for me so bummer that the gateway will be the Blackbox... Thanks @willow_hiller for the picture!
Would be nice of Tesla to actually do the Solar gateway aesthetics like the Powerwall as well to give it that nice branding touch!![]()
what brand of load centers does Tesla install? Square D?
Thank you for sharing... How big is your system?We haven’t gotten our install date yet but I found this in our permit.
- Panels: Hanwha Q.Cell Q.PEAK DUO-G6+/SC 340 x 27
- Inverter: SolarEdge Technologies SE7600H-US
- Gateway: ??
- String optimizer SO5000 - is this the Gateway?
Also, should the Power blaster be another piece of equipment? I saw reference to it on another thread.
- Gateway: ??
Spot on!!!340W x 27 panels = 9180W or 9.18kW system size
That optimizer is interesting. It looks like it’s one optimizer for the entire string, rather than one per panel. I haven’t seen an install using that optimizer yet.
is that a good or bad thing? Hate the idea of being a guinea pig!!
