The Ludicrous Cubby Flyout Situation
Discussion in 'Model X' started by HabitualUser, Nov 5, 2018.
Tags:
  1. HabitualUser
    HabitualUser Member
    Los Angeles
    When I go pedal to the metal, my third-party cubby often flies out. Does anyone have a hack to keep the cubby in place?
    I see some vendors selling cubbies that lock, but they are pricey and not that attractive.
  2. jajabor
    jajabor Member
    San Ramon, CA
    You could try adding rubber/foam padding using double sided tape..
  3. bFlat
    bFlat Member
    San Francisco
    The Norm Cubby is designed in a way to stay in place:
    Vendor - New Cubby Drawer
    There is a ridge on the lower edge of the cubby space. The Norm design uses the ridge to keep the cubby in place instead of relying on friction. It's the only design I know of that works this way. I've had no problems and the fit is perfect on my MX.
