The Model S Driving Dilemma
Discussion in 'Model S' started by Velo1, Sep 22, 2012.
Tags:
  1. Velo1
    Velo1 Member
    Evergreen, Colorado, United States
    When I do eventually get my Model S, I foresee a dilemma. When approaching an intersection where the light turns yellow, do I punch it or break to stop.
    If I punch it, I know the car will instantly accelerate and I will glide through the intersection with a satisfied smile. But if I brake and stop, I will have the pole position for the pending green light launch, which will also bring a satisfied smile to my face. Actually, maybe I should just take turns, as either decision is a win-win.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Speaking as a Roadster owner... brake to a stop!
  3. AnOutsider
    AnOutsider S532 # XS27
    Haha, I thought the dilemma was going to be: Do I punch it or brake and stop because I don't really have space to regen brake smoothly?
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    Agreed. Technically a yellow light means "Stop". It's not a warning that a Red is coming. My brother went to court over a Yellow Light ticket and lost for this very reason.
  5. Doug_G
    Ottawa, Canada
    True but that wasn't my reason... :tongue:
  6. Velo1
    Velo1 Member
    Yellow may mean stop, but I have always treated it as "hurry up and go", and have never had a ticket doing this in 45 years of driving. Either way, I will heed the advice of the Roadster owner. Take the pole position and tell any passengers to brace for take off.
  7. mknox
    Toronto, ON
    Most do treat yellows that way. In my brother's case, the officer noted that he both entered and cleared the intersection while the light was Yellow, but deemed that he could have stopped. The Judge agreed. I think the cop was being a jerk. Typically, they ticket for a Yellow if the light turns red while you're going through, but "technically" Yellow does require you to stop.
    I think the bigger reason for stopping is in case someone in the opposite direction decides to make a left in front of you when the light goes yellow!
  8. brianman
    brianman Burrito Founder
    From our audience in space:
  9. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    Around town there have been a lot of these pedestrian crossing lights that count down. And most of the time when the count ends the yellow light begins. It helps me plan my speed entering intersections even better. The real questions is if I see 7 ... 6 ... 5 do I start slowing down or speeding up?
  10. cinergi
    cinergi Active Member
    MA
    I *LOVE* being first at red lights. So if I'm coming up on a yellow, I take that as an opportunity to floor it when it turns green (paying very close attention to my surroundings to make sure no one's gonna run a light, pedestrians, etc. because you're going to be on the other side of that intersection than anyone's going to predict) :smile:
  11. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Old Australian joke:
    Woman arrives late at the airport in Sydney and jumps into a taxi. The driver is driving normally, when a bit ahead a light goes yellow. He accelerates! The light goes red, and he really floors it, and goes through the intersection just as the other direction's cars start to move. The woman is a bit shaky but doesn't say anything.
    A few lights later, the same thing happens again! Now she's starting to get worried.
    Then the taxi is cruising toward a red light, slowing gently. Suddenly the light goes green. The driver jams on the brakes and comes to a panic stop at the green light!
    "Why did you do that?" she asks.
    "My brother might be coming the other way!"
  12. jerry33
    Texas
    +1. There is an intersection on my commute where that kind of collision happens with depressing frequency.
  13. Bifff67
    Bifff67 Member
    Northern Virginia
    It can be more complicated. Is there a Mustang or M3 near? Porsche? What did they do? Act accordingly. Stragedy...
  14. digitaltim
    digitaltim Sig737 VIN628
    MD, USA
    Yellow == Clear the intersection here in MD...
    That said, I think I will be breaking to get the better pole position assuming the light turned yellow before I entered the intersection.
  15. Doug_G
    Ottawa, Canada
    Obviously that cop either (a) was an idiot with nothing better to do, or (b) had a quota to meet. And I really doubt your brother had enough warning time if it was still yellow when he exited.
    Absolutely. If there's someone waiting to turn left, then I'll definitely stop if I can do it without drama.
  16. ckessel
    ckessel Active Member
    I think the law on yellow lights might vary. In Oregon its "could you have stopped?", not "did you clear before red?" Our lights change immediately, my red is your green, so pushing a light is really dangerous because someone may be hitting the green light at full speed, which is common on the streets with timed lights.
    I know some states though have delays from my red to your green precisely because running yellows is so common.
    Me, personally, you push the edge of a yellow then a sniper should blow out your tires. But hey, that's just me :)
  17. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Technically a yellow light means "CAUTION" in many states. The law states that you should stop if it is safe to do so. (I won that one in court, actually. It was raining.)
  18. STxTesla
    STxTesla Sig #1278
    Corpus Christi, Texas
    I would opt for the stop on yellow...there could be another Model S at the intersection ready to take off.
  19. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    Indeed.
    I'm always on the look out in the Roadster for potential drag-race victims :) Same goes when on my motor cycle. Won't be any different in the S.
  20. mulder1231
    mulder1231 Active Member
    SF Bay Area
    I first look in the rear mirror before making a decision. Sometimes the guy behind you has already decided that he's going to make the yellow light as well. He'd be at fault for hitting me, but I'd rather avoid that situation.
