Pulled a generator I sold 129 Miles one way, and then returned home another 129 miles a few days later. All I can say at this point, is that I cannot wait until I get a Teardrop camper!!! That will be awesome!
The hitch is made by Torqlift Central, the EcoHitch series. About $320. I have another video in this forum and on my channel with the installation. It goes between the bumper and the car. Very sturdy.Excellent!
I want to do some towing when I get my car.
This must be a custom tow hitch. Was it much drama getting it made? How is the tow hitch mounted to the vehicle? You would need some strong mounting points because the car has no chassis.
Did make me think that Tesla's back-in, edge-of-the-lot charging is 't good for people towing.
Almost every SC I have visited has at least 1 space you can pull straight into, mostly for those reversly challenged![]()
I've only been to 2 Superchargers so far -- Flagstaff and Buckeye. All stalls at both sites are back-in only...
Do you want us to update the title? Sounds like you pulled the trailer 129 miles.
129 with generator.
129 w/o generator.
If the supercharges are vacant, you can always pull up to a stall like a gas pump.
Zno, pulled it 129 with generator and then another 129 home without generator.Do you want us to update the title? Sounds like you pulled the trailer 129 miles.
Maybe you could clarify that with your first post because it reads to me like you pulled it one way and then just drove the car back.Zno, pulled it 129 with generator and then another 129 home without generator.
@islandbayy: please could you give some written details such as range achieved before needing to charge? I also found the headline and first post misleading.
Tip: Like a lot of folk I'm accessing TMC via phone much of the time which makes it tough to follow the video plus it would be really helpful to read your key points in a few sentences rather than watch a 12min film.
I'm not planning on loading anywhere near that much on my MS. I am going to be purchasing a Teardrop from RetroRide Teardrop Trailers, Teardrop Campers, and Small Campers Most Likely the 5x8. It weights less then 1000 lbs with Air conditioner. That leaves some room for Gear. Although, I'd rather have gear in the Model S, it would be more Efficient. Apparently, someone from Texas (Arlington I believe) already drove up to them, and picked up one of their Teardrops after seeing my post on them here last year.I've been told not to do it, but has anyone tried towing 1700+lbs? I'd love to be able to tow one of these. Alto Travel trailers by Safari Condo
