"The Model X will only be offered as all-wheel-drive" - Elon Musk
Discussion in 'Model X' started by MartinAustin, Oct 24, 2013.
  1. MartinAustin
    MartinAustin Active Member
    Austin, Texas USA
    #1 MartinAustin, Oct 24, 2013
    My first post to the Model X forum! :)
    Elon Musk just said this at the London store-opening event... like, about 5hrs ago.
    Check this video at the 24:10 mark. (horrid bandwidth video, but you can hear what he says)
    Tesla London Store Opening reception with Elon Musk - YouTube
    Perhaps this is for the U.K. market only? The web site still says RWD will be available.
  2. Citizen-T
    Citizen-T Active Member
    Raleigh, NC
  3. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    No RWD drive option in the US? Not like I was going to take that option but that should raise the base price of the car about 4 to 6K presumably. Seems odd to not offer RWD as I can't imagine that the motor wouldn't be powerful enough.
  4. MikeL
    MikeL some guy
    #4 MikeL, Oct 24, 2013
    Wow. Once again, you heard it here (TMC) first folks! One less option to choose, AWD is the reason I'm waiting for the X. So at least it won't cost "extra", but it sure will cost "more" ! :tongue:
    ML
    I'm thinking maybe the complexity of the AWD makes the 2 wheel & 4 wheel models so different that they have decided to just go w the more advanced option, at least to start. A lot of people in LA, Atlanta, etc. pay more for 4WD they don't "need"
  5. wts13
    wts13 Member
    Bay Area
    I don't like this at all. Lower range with same battery size (I'd assume) compared to a 2WD, and higher cost.
    For those of us who live in sunny California and never encounter snow or any challenging driving conditions, I'm not sure why it's a good thing that we have to pay more in up-front cost and in energy usage.
    I'm increasingly concerned that the Model X is going to be insanely expensive for what it is. Hope I'm wrong :/
  6. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    Some of us who live in sunny California encounter snow and other challenging driving conditions and were planning on AWD ... so this is a non-issue for me. But I'm sure it's an issue for others.
  7. aronth5
    aronth5 Long Time Follower
    Boston Suburb
    Clearly not the only reason but I believe Tesla has determined that without taking advantage of AWD they cannot get enough range out of the larger and heavier Model X. Elon is dead set on a minimum 200 mile range and I don't think the 60 with rear wheel drive can achieve that without leveraging different gear ratios (I know that is the wrong terminology but you get my point).
  8. MikeL
    MikeL some guy
    Re: more power draw from 2 motors
    There was a thread (which I will now go look for) in which it was argued that the X will use more power, but only because of its weight, NOT due to having to power another motor for the front wheels. Each motor works less, sharing the work, but the same amount of work, so no extra draw (or negligible extra).
  9. Palpatine
    Palpatine Banned
    Seattle
    I think there is likely some savings by reducing versions.
    Having to build AWD and RWD versions of the Model X is likely more expensive for both. If they decide to make all of the Model X line as AWD, there might be more overall savings because there is less development work (one instead of two versions) and higher volumes for the AWD.
    Their think is likely, if someone does not want AWD, then buy a Model S.
  10. andrewket
    andrewket Well-Known Member
    Actually an AWD model X may be more efficient. The two engines can be geared differently, and the car can shift which one is propelling the car. It doesn't always have to be about traction. Similarly, it may be more efficient on regen and less stressful on tires.
  11. wts13
    wts13 Member
    Bay Area
    I'm certainly not an expert, so if this is true, that's definitely a good thing. Hope it doesn't drive up the price too much.
    I still hold out hope that we will see a slight bump in battery capacity for the X. Anything less than the range of the 85kw Model S makes it a non-starter for road trips especially if a trailer is involved - something that SUVs are used for far more often than cars.
  12. qwk
    qwk P130DL
    There is going to be severe sticker shock when the price of the model x is finally announced.
  13. andrewket
    This is what I'm afraid of as well.
  14. Citizen-T
    Raleigh, NC
    As you might recall, there was "severe sticker shock" when the price of Model S was announced.
  15. brianstorms
    brianstorms Member
    On the Great Britain site, at http://www.teslamotors.com/en_GB/modelx the message is that it'll be available in 2WD, AWD, and AWD Performance versions. So either something has changed and the site doesn't reflect that yet, or Elon's wrong.
  16. brianman
    brianman Burrito Founder
  17. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Elon does not say the X will "only" have AWD, he says it "will" have it. There is a difference. He may well mean that AWD will be an available option.
    He also says it "will" have two motors, not that it will "only" be available with two motors.
  18. brianman
    This is the exact quote (around 24:20):
    So...yah, he kind of did say "only". :)
  19. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    It may be more efficient, in that it gets more work out of each kWh, but the required energy to propel the Model X will be higher. This is due to two reasons:
    - The Model X will have a larger aerodynamic area.
    - The Model X will be heavier.
    The most important reason is the first one. More interior space = increased energy consumption.
  20. doug
    doug Administrator / Head Moderator
    SF Bay Area
    My guess it's more an issue of time, resources, and priorities. They need to deliver an AWD version, and that's the version the Model X is essentially being designed to be.
