The New RAV4 EV
Discussion in 'Electric Vehicles' started by EVNow, Jul 16, 2010.
  1. doug
    doug Administrator / Head Moderator
  2. jcstp
    jcstp Active Member
    Belgium
    yes, pics are from bonnie, when she visited the factory!
    But I think she pulled the photos (I couldn't find the photos anymore afterward)
  3. JRP3
    JRP3 Hyperactive Member
    Central New York
    If this comment is to be believed:
  4. strider
    strider Active Member
    NE Oklahoma
    I have on good authority that that comment is true.
  5. TonyWilliams
    TonyWilliams Active Member
    San Diego - Tesla powered Rav4 EV
    #825 TonyWilliams, Nov 13, 2012
    Chris is hosting a workshop on Dec 1, and I will build two 75 amp "portable" EVSEs. About $600 each.
    - - - Updated - - -
    That fuse block (with the two battery cables attached to each end) looks very similar to that in the Rav4.
  6. TEG
    TEG TMC Moderator
  7. JRP3
    Central New York
  8. ChrisHenryOC
    ChrisHenryOC Member
    Orange County, CA
    I've set up a wiki-map (like the one we have for Tesla Reservation holders) on which Rav4 EV owners can post their locations. I'll approve them as they come in.
    Here's how to add an entry for yourself (and your Rav4 EV):
    1. Point your browser to: Rav4EVOwners
    2. To add a marker, use the Additions/Add Marker - Simple drop-down.
    3. Enter in your forum name, your car's color, and your location
    4. Submit your entry
    5. Wait (semi-patiently) for me to approve your submission
    If you want to just enter your city, feel free. I turned on the setting to hide street addresses for those of us who are semi-security conscious.
    I'm curious to see where all of you, and your cars, are. Any out of staters?
    -Chris
  9. TonyWilliams
    I have to admit, I was dubious that the Rav4 would really have 41.8kWh usable, but after running it to "turtle" mode (same as the LEAF), and measuring over 50kWh at the EVSE getting pumped back in, I'm a believer.
    I did drive the car 130.1 miles on a rental. Here is my second draft of the range chart for this car. Lots of work to do, but you'll notice that I've highlighted the EPA ratings, which appear to be achieved at 2.7 miles/kWh.
    The fuel gauge, unfortunately, does read above 80% capacity. I don't know why Toyota/Tesla thought that was wise.
  10. jcstp
    jcstp Active Member
    Belgium
  11. Lloyd
    Lloyd Supporting Member
    San Luis Obispo, CA
    That's a great deal!! I love the Rav 4 EV !! Purchase 49,900, + tax & lic, = ~55,000 - 7500 Fed tax credit, -2500 State (CA) - 5,000 Toyota rebate = ~ $42500 out the door. and 0% financing!
  12. jcstp
    jcstp Active Member
    Belgium
  13. JRP3
    Central New York
    So they hope demand for it picks up in other parts of the country, but it's not for sale in other parts of the country...
  14. TonyWilliams
    That not what she says at 4:50. It was clear that 2600 through 2014 in California only (and not specifically stated is the Zero Emissions Vehicle credits from CARB) is all that's planned today, however AFTER 2014, if there is demand (and with only 140 sold so far... not looking so good), then they would look at what to do post 2014.
    I predict it will be exactly what they did in 2003 with the previous Rav4.
  15. vfx
    vfx Well-Known Member
    CA CA
  16. Toasty
    Toasty Member
    Alpharetta, GA
    i want one, i just wish they would do nationwide service.
  17. tommolog
    tommolog Member
    Northern NJ
    #838 tommolog, Feb 16, 2013
    I was thinking about the onboard charger for the RAV4 EV. I had assumed it was the same one as the standard 10kW charger on the Model S but then everything you see says the maximum charge rate is 9.6kW(40amp X 240v) while Tesla says the S charges at 10kW. I know it's splitting hairs, but is it the same onboard charger and they just list the charge rate differently? It would be surprising if they actually made a different charger since most of the other components are shared. Also is the onboard charger three 3.3kW chargers stacked together?
  18. Lloyd
    San Luis Obispo, CA
    I believe that the rav got the 9.6 kw designation due to the recommended EVSE pairing with Leutron which has a maximum output of 9.6 kw. I use a clipper creek ts-70 converted to J1772, and see a full40 amps rate.
  19. tommolog
    tommolog Member
    Northern NJ
    Thanks Lloyd. So even on an EVSE like the TS-70 that can supply up to 70amps the RAV4 will only pull 40amps which is 9.6kW then, interesting. So would you know if the Model S limit it's draw to 9.6kW also if you were charging it from a 70amp supply?
    Like I said, I know it's splitting hairs here, I'm just curious if there is any difference in the two charging systems. I had figured they would be identical.
