The perfect Model 3 emergency jack?
Discussion in 'Model 3: Interior & Exterior' started by mswlogo, Nov 28, 2018.
Tags:
  1. TydalForce
    TydalForce Member
    West Chester, PA, USA
    How easy/hard is that to do? It's not clear from the listing if that's just a matter of taking a wrench to it, or getting more complicated (destructive).
  2. jrweiss98020
    jrweiss98020 Tessa's Tesla
    Edmonds, WA
    What does the Porsche jack cost - $300?
  3. jrweiss98020
    Edmonds, WA
    Also, if you already bought jack pads, why do you have to remove the top fitting? You might just cut some wood or HDPE to fill it, if you want...
  4. mswlogo
    mswlogo Well-Known Member
    MA, NH
    It doesn't, people have paid any where from $60 - $120
    You might see a few listings with the spare that like new for much more.
    This is the cheapest one I see right now $125
    1999-2004 Porsche 911 996 Boxster 986 Spare Tire Emergency Tool Kit | eBay
    Lots of ways to look it up
    I just bought one with the spare tire (they refused to break it up) for $150 and sold the tire for $60.00
    They constantly come and go and you can wait for a good deal.
    Some are really beaten up, so check pictures and reputation carefully.
  5. jkoya
    jkoya NA2 NSX
    Northern CA
    I've been using a high density polypropylene commercial grade cutting board. Easy to clean and it's been pretty tuff so far. Hasn't cracked despite my best efforts to abuse it over the last few years...
  6. LaurentR
    LaurentR Member
    San Jose, CA
    The HF 1.5T aluminum "Racing" jack is pretty much the standard out there. If you go to the track, you'll see > 50% of people using one of the many versions they have made over the years. These things are inexpensive, decently small, reasonably light, fast, go pretty low (I have jacked many much lower cars than the M3 with it) and surprisingly durable given all the above. Highly recommended.
  7. mswlogo
    MA, NH
    I have a similar one for my garage (with a different label).
    Way overkill to keep in the car for just emergencies, IMHO. Also, any hydraulic jack can leak.
    Harbor Freight (or one of the 100 labels) is 33 lbs vs the Porsche (emergency) jack is a bit over 3 lbs.
    The Harbor Freight one isn't full aluminum.
    Company's (China of course under many labels) do make them with much higher % of aluminum that shaves about 10lbs off for 2-3x the price.
  8. Ellsworth
    Ellsworth Member
    Los Angeles
    You mean instead of my socket idea? I'd be very concerned about any locating solution being deformable or breakable. All the jacking pads I've seen were a hard slippery plastic (like Delrin, used for suspension bushings) or solid milled aluminum.
    -E
  9. Ellsworth
    Ellsworth Member
    Los Angeles
    (Sorry for the late response)
    As you can see in the photos from my article, the washers were from a Hillman brand assortment of neoprene fender washers from a hardware store (Virgil's in Glendale, CA). I've never seen those anywhere else, and I often browse these parts of hardware stores.
    I just searched for "neoprene fender washer" at Amazon, and there a lot of choices there.
  10. jkoya
    jkoya NA2 NSX
    Northern CA
    Thanks !! I actually found them at the local Ace Hardware..
  11. Ellsworth
    Ellsworth Member
    Los Angeles
    Yes and no. As you can see from this photo, our Model 3 with unmodified suspension and properly-inflated tires could probably clear Porsche jack with a typical Tesla jacking pad adapter "puck" at the rear jacking points, and probably the front. You could lift the car by hand to gain some additional clearance. But on a deflated tire, and on a surface of unpredictable flatness, I'd want all the leeway possible.
  12. Ellsworth
    Ellsworth Member
    Los Angeles
  13. PianoAl
    PianoAl Member
    Far Northern California
  14. webbah
    webbah Member
    Lucerne, Switzerland
    That’s great to hear. I was getting bashed here for posting it but honestly I think it’s a great deal for something we hopefully rarely ever need to use.
  15. TonyJag
    TonyJag Member
    Central MA
    Thank you for all of the great information posted here.
    FYI, I just posted a story about Porsche Jacks with the Modern Spare kit in another thread:
    Anyone Buy Modern Spare Tire Kit?
  16. puckpurnell
    puckpurnell Member
    Connecticut
    After mulling for 20 months, just ordered the Porsche scissor jack.
    • Funny x 3
  17. KenC
    KenC Active Member
    Maine
    #217 KenC, Oct 2, 2020
    I may have a pic of it earlier in this thread, but I use a scrap piece of IPE decking. It’s incredibly dense, so it doesn’t absorb water, and plenty strong enough to support the jack without cracking. With the Porsche jack, you can crank it all the way up and even rotate both tires, if you feel the need to put your compact spare on the back, keeping a full-size tire on the front.
    I vaguely recall the seller many of us have purchased from is SpecializedGerman. He usually has a jack in its original foam donut that can fit inside the spare.
  18. scissorfighter
    Maine
    What a great idea! Thanks @mswlogo ! Just got my 911 jack today and it’s excellent.
  19. flyingpenguins
    #219 flyingpenguins, Feb 10, 2021
    50A65286-AD04-4B5F-B067-A1243C2C0626.jpeg 2A3215B4-B258-4DBB-98E1-55167E1A6134.jpeg I got an OEM Porsche aluminum jack from eBay and have been sorely disappointed! I cleaned it up and regreased the thread. I couldn’t manage to get a rear tire up on solid ground because I absolutely destroyed the skinny aluminum wrench (the aluminum bent stick with a handle on one end and a hook on the other).
    I got a scissor jack to 13/16” or 1/2” drive adapter and managed to get the car up, but not without serious warping by the time the tire cleared the ground. I used chocks on the other side and I think the jack may have called it quits without the chocks!
    I think I’m going to keep searching for a sturdier scissor jack. I’m not sure any of the usual suspects on Amazon look any better...almost all of the popular ones have some photos of them failing.
    • Informative x 3
  20. Avid
    Avid Member
    Houston, Tx.
    That's very disappointing. :(
    I had considered purchasing one of those.
