YMMV. The flat metal machined portion of the Porsche jack, with rounded nub will contact the painted area around the jack point hole - potentially scratching the paint around that hole, leading to rust. There is a reason why all jack pads are either made from all nylon like material, or are metal with nylon-like pads. This is the reason, I believe. Good luck if you choose the other posters, “ nothing needed” suggestion.
There is a need, I believe. All metal jack pads have a non-metal gasket of sorts. Hockey puck or composite non-metal pads don’t need a gasket as those materials are softer and easier on the paint surrounding the jack point hole.
As I noted on the opening post, I don't like jacking up ANY car from the body. It twists the body and you have to jack it up a lot higher. If you don't know how, don't do it. If you want to jack up from the body either file the nub on the Jack or take it off completely and use a standard Model 3 lifting puck. You should practice jacking up the car and not wait until your possible first emergency. I need to test the Jack on my Model X now.
Hmmm, I guess more votes for rounding the nub? and if it does indeed only take 10 minutes, I should just try rounding first, then see where it leads me to. And yes, I do intend to give practice before using it in actual emergency situation. Thank you everyone! Edit: I guess for rounding the nub, I can just use the manual metal file that I posted earlier correct?
yes that should make short work out of the job, remember to use low speed on your cordless if it has multiple speeds
Thanks! My power drill is corded and about 7 years old. It looks kinda similar to this one. https://www.amazon.com/DEWALT-Corded-7-0-Amp-8-Inch-DWE1014/dp/B00FI0NQO4/ref=sr_1_13?crid=MFJP1VR91HYU&keywords=power+drill+corded&qid=1569274756&sprefix=power+dri%2Caps%2C209&sr=8-13
I used a fiber disc on a 4 1/2" angle grinder and it took less than 1 min. others have used a file and said something like 10 min. the 60 grit stone you linked would be less than 5 min is my guess if you want precision and are looking for the best finished look go for the file, I gouged mine a little with the grinding disc but looks were not important, it still works just fine and again pictures of what i did to mine are on post #15 of this thread
I don't mind the look so as long as it's functional, so I think I'll most likely go with the grit stone. Going back to your post #15 after actually receiving and seeing the jack, I now understand what you did. Thanks again!
I'm sure they will eventually rust, this one jack point here scrapped on a large speed bump or something I guess? I'm not really concerned about this area having rust so bad it will compromise the strength of the steel, my best guess is here in CA it might take 10 to 15 years to do that much damage, I could be wrong though?
We ride along in Tesla Mobile Service's customized Model S - Video Tesla service ranger doing a tire rotation with one jack lifting the whole side, it would seem to me that if it was too stressful for the car then they would not do it this way (see video starting 1:12)
Why not get the jack from Modern Spare? It's specifically designed for the Model 3 and has a built-in rubber pad: 4000 LB - TruLift Ratcheting Scissor Jack w/ Rubber Contact Point - Modern Spare I think for $35 + $15 shipping is reasonable.
I'll tell you why.... For details, my review can be found below. TruLift 4000# Ratching Scissor Jack Review (Modern Spare)
Just picked up the Porshe OEM aluminum spare jack from partssociety.com for $65. Came with foam insert too.
I missed out on an EBay auction for a second one for my Volt. It went for $61 and looked mint. BTW the one I had for my Model 3 lifts the Model X easy.
Really? I was looking on eBay and they were all over a $100. Was happy to find this one cause it looked brand new.
I wonder if it would looks like the following: Cayenne AWD Porsche 955 Jack Lift ? - I have a similar one made of aluminium from an Audi. This is not really strong enough to raise the full car. I use it at the front and use a scissor on at the rear. I would also recomment to get a square pice od 10"x10" pice of wood in case you will have to raise the car above mud. And also to design a Hockey Puck to help center the jack just under the lifting area hole.
The jack looks like this. If you go through this thread you can see how well it works and how you can modify it to fit the Tesla jack points.
Exactly, which why it was a good deal. Look at Sold listings. It was an auction. I paid over $100 for my first one. I’m in no rush.
