The puzzle of the iPhone dock
Discussion in 'Model S' started by Jeff-6293, Jan 31, 2017.
Tags:
  1. Jeff-6293
    Jeff-6293 Member
    Nashua, NH
    I must've failed "puzzles" in third grade because I look at the collection of pieces and cables that came with my model S for the iPhone dock and I cannot figure out how to install it. Does anyone have good pictures of how it gets installed or what it looks like once it has been installed?
    Thanks
  2. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Took a little head scratching on my part as well but it's not too bad in the end, and it works really great (the guides help slide the phone right into position without even looking).
  3. BestRadar
    BestRadar Member
    NJ
    Depends on your phone case if the phone will plug into it. I have to remove my case to charge my phone. They should have made the connector a little longer.
  4. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    If it's like the one on the Model X I had delivered last week, the SvC gentleman removed a fair number of "floor" parts, with his fingers - no tools, en route to routing the cable from guggle to zatch. Not complicated...if you know what you're doing. Good luck.
  5. fasteddie7
    fasteddie7 Member
    uniontown PA
    Here's a video of someone taking it apart to put in a USB-C so you can see how it gets assembled
  6. Joe F
    Joe F Disruption is hard.
    Outside Philly
    IMG_2390.JPG Just make sure to hand thread the screws. Whoever tried to install mine cross threaded one, and then spun the piece it threads into in the plastic, so it was really tough to remove.
    As stated, if you use a case on your phone the side guide pieces that snap into the side and bottom slots may not accept the phone. Also the phone may not slide down low enough to seat the power connector. There are a few threads here that have workarounds, but not helpful if using the guides. I wound up using a Dremel to plow out the plastic to sink the cable lower rather than cut part of the strain relief away.
    Don't do what the picture shows :mad:
  7. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    I hate cases, always had the phone "naked" so no issue here. :p
  8. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    With a little delicate Dremel work to extend the charging spade, I got mine to fit with the case on.
  9. Joe F
    Outside Philly
    I did too, but the side guide spacing isn't deep enough to accept my case.
    Did your case fit, or are you going without the guides in place?
  10. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    My IPhone 7 is pretty skinny and so is my Otter case, so it fits snugly in the guides.
  11. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Almost impossible to plug it in while driving. The sweet spot is harder to get than something that I won't mention!o_O
  12. Gt1948
    Gt1948 Member
    Millington TN
    Pictures?
