So I did a thing over the past couple weeks. Now bear in mind, this is all for autox.
18x11 +40 Konig Hypergrams and 295/35/18 RE71RS. Rears went on as is, but the front required some shaving of the upright and a spacer. In this case the 17mm MPP spacer worked perfect, as well as MPP extended studs.
I'm running Redwood Ohlins Race/HPDE coilovers and sways, and MPP for everything else.
I've lowered the front to 26.25" ground to fender, but will likely bring it back up to 26.5" next time I'm in the wheelwells.
I haven't done an alignment since lowering the car, but was at about -2.5* camber and then lowered it 20mm. So I'm guessing somewhere around -3* currently.
We used a couple different spacers for fitment to see where we needed to be, then put on the 17mm MPP spacer for a semi-perm install.
The shaving was to get the wheels to fit, not so much the tires. Although I don't know if I could go wider up front. The extra width of the rim causes the tire to be a hair wider. I'll throw on a 315/30 from a friend's car who's got 18x11s to see if it could possibly fit, but I doubt it. Rears could probably take a 315 no problem.
The rears were just plug and play. I still need to install MPP camber arms and then lower. Currently it's about 27.25" ground to fender. Camber is only at -1.1* at the moment. And yes, I know that's not nearly enough for autox.
I drove it around a bit seeing if there was any rubbing. There wasn't from wheel or tires, but the factory mud flaps up front had a bit of self clearancing to go thru. After that I drove it 120mi to the first big autox of the summer season (Packwood, WA).
autox went really well, but I'll post that in the autox thread.
