The shudder problem: Current status (end of February 2020)
Discussion in 'Model X: Driving Dynamics' started by ElectricSteve, Feb 27, 2020.
  1. TSLA Pilot
    TSLA Pilot Active Member
    United States
    And, for another data point: yes, it's in the Model S Raven Performance as well; others, IIRC, have reported it in the Model S non-Performance.
  2. TSLA Pilot
    United States
    Mods:
    Could we please have this thread moved so it's findable for both Model S AND Model Y owners?
    Thanks!
  3. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    If you'd like to get a mod's attention, the best way is to use the "Report" function. I happened to see this because I watch this thread.
    It's a hard call, because this thread has a number of specifics to the Model X, like part numbers. Some issues are clearly cross-platform with little differentiation (think Autopilot), but something like this is probably better off having separate threads for each particular model. I think if one wants to discuss shudder in Model S, they should start a thread in the Model S section - and similarly for any other model. This thread should really be reserved for discussing the issue on Model X.
  4. TSLA Pilot
    United States
    Duly noted, and arguably correct, except that the new half-shaft part numbers are also applicable to, and solve the problem for, the Raven Model S's as well.
    At twelve pages so far, I'm not sure where this was documented exactly, but if anyone here could confirm this (again) on behalf of your Model S brethren, that would be appreciated.
    Once that's done, I hope we might perhaps find a way to at least change the title to include the Model S, even if it's left in this Model X sub-forum?
    Thanks!
  5. blove
    blove Member
    denver
    My 2021 MX is a performance and has the shudder at around 700 miles already.
  6. johnking
    johnking Member
    North Bend, WA
    Thanks @blove for confirmation and hoping Tesla has a fix for this soon. My Model X delivery has been moved to next quarter. Keeping an eye on this thread.
  7. TSammy
    TSammy Member
    Georgetown
    My 2016 MX has had 2 replacements under warranty and 1 more when suspension was slightly damaged in an accident.
    All 3 were with the newer 1/2 shafts.
    In all 3 the shudder went away for a while and returned after 4 to 5,000 miles.
    Low suspension setting has always worked as solution.
    I now just set “chill” mode and get a 20% discount on my insurance.
    • Informative x 2
  8. LukeSki
    LukeSki Member
    UK
    I have it on my 2020 MX Performance, 4,000 Miles. Even on low ride height, SC said they couldn't hear a noise or find anything wrong with it.
  9. Vitaman
    Vitaman Supporting Member
    Decatur, GA
    Had mine replaced 3 days ago.
    I have stellar guys at my service center but still had to push past the “ it’s a known problem “ rhetoric.
    Car went from a high performance combustion engine attempting to run on low octane fuel to the silent assassin I used to know. Night and day difference!
    So nice to be driving a Tesla again!
  10. Kyle [CK]
    Kyle [CK] New Member
    San Diego
    I have been through this myself on my ludicrous P100D. The issue is the half shafts moving left/right as they develop play in them due to wear. Design flaw for sure with how the clevis mount is setup. I just have learned to live with it and know it will be there at full charges etc.
    hopefully it gets fixed on refresh!!
  11. Hodginator
    Hodginator Member
    Virginia
    Well, unfortunately about 3,200 miles after the half shaft replacement a slight shudder has returned (suspension on low) which is very similar to how it started in the beginning. For reference I have a May 2019 Raven. The following are the part numbers for the half shafts they installed.
    • Front Halfshaft, Model X, LH, PM(1027113-00-B)
    • Front Halfshaft, Model X, RH, PM(1027119-00-B)
    Based on epc.tesla.com it appears the above are the latest half shafts. I'm assuming this means the issue is not resolved unless there are new half shafts that aren't listed.
  12. Vitaman
    Decatur, GA
    Disappointing news.
    Messaged my Svc Center bro verify the part numbers they used.
    Has to be depressing for you.
  13. n1h1
    n1h1 Member
    Madison, WI USA
    For those that have requested a fix, how much arm twisting do you have to do? When you report the symptoms do they automatically setup the parts for order in advance before the appointment, or do you find yourself having to go in and then argue with them after they look at it and say "oh this is expected behavior", and then later go back for a second appointment to actually get the fix done.
    (the reason i ask is it's a 1.5 hour drive to my SC, so always a PITA to take it in)
  14. Vitaman
    Decatur, GA
    For me I had to complain for a while.
    Their reply was always it's a known problem and eventually they will have a fix.
    As my issue became worse I was not enjoying the car at all.
    Finally I said that I new several folks on this forum had solved their problems by replacing parts.
    They are busy and it took a mechanic all day long, so maybe they were loathe to use manpower like this?
    Whatever. It's their job! And it was a great solution.
  15. dmurphy
    dmurphy Woof.
    New Jersey - Morris County
    So let me ask... when we talk about "shudder"... does it include a clunking sound as well? I get a clunk-clunk-clunk when moderately accelerating from stop. Feels almost like something is loose - might even be in the rear. Before I take it in and get a "this is a known issue" - is that a symptom you all are seeing?
    June 2020 Raven build, 15,437 miles before you ask :)
  16. ChiJim
    ChiJim New Member
    Miami
    I have an Oct 2020 build date Model X and experienced shudder from day-one. It got progressively worse and I took it in for service. The front halfshafts were replaced with the 2nd Gen parts listed below. Maybe it's just my per perception, but beyond eliminating the shudder, the car seems to now drive much smoother at every speed. Very pleased.
  17. ohmman
    North Bay, CA
    That is not the same thing. The shudder is a vibration from the front of the car that can be felt in the cabin. It's relatively inaudible but you can definitely feel it. It's also reproducible under acceleration in certain speed ranges.
  18. dmurphy
    dmurphy Woof.
    Thank you my friend! I don’t feel anything in the wheel but you can certainly hear it. Definitely a problem. Scheduling service now.
  19. Vitaman
    Decatur, GA
    I had the sound issue like dmurphy.
    Several people convinced me that it could be called "Shudder".
    Regardless, the Shaft replacements instantly eliminated the problem.
  20. mac500
    mac500 Member
    Belgium
    My new Model x, delivered on 18/12/2020, is having the same issue. When acceleration I hear this strange noise coming from the drive train in the front. Not yet really heavy shudder but I have a service appointment next tuesday so I'll hope they are going to fix it. 4750km driven in total since the delivery ...
