Elon has said the Semi will have about a one-ton weight penalty versus diesel. If weight is added for a sleeper cab, it will still be a one-ton penalty -- no difference (maybe a little less since Tesla is very good at finding ways to reduce weight). As for A/C and heat, Tesla has already developed highly efficient HVAC systems for its vehicles. In fact, Elon has mentioned many times that Tesla may even get into the home HVAC business. Other amenities for a sleeper cab shouldn't be that difficult. Since the first couple years of the program will probably involve relatively low volumes as big companies test out prototypes before making large orders, there is probably no urgency for Tesla to roll-out a sleeper version. But I think it's a mistake to be thinking about the Semi as limited to short-haul. Tesla is definitely going after the long-haul market IMO.
I feel the same way in that the Semi business is completely overlooked. 1st people talk about the Cars, then FSD, then Batteries. All those are huge but then you add in selling $200,000 trucks like hot cakes and FSD subscription on top of that. Money will just be flowing. Short haul: 0-60 is going to be crazy. Charge while the trailer is being loaded/unloaded. No need to stop to fill up off the route. Long haul: FSD is going to make fatigue way less for the drivers. The seat may as well be a LayZBoy that they can recline and take a nap. Note: I've never driven a Semi, just a WAY outsider's POV but still think its yet another 'game changer' from Tesla.
I believe the one-ton weight penalty is all about the battery pack and nothing else. It will be one less ton of freight/cargo that the Tesla Semi will be able to haul legally. That one ton will also give the TS less range. Regardless of how efficient the HVAC is it will still take more energy for more space. The first couple of years TS's will not be prototypes, that is what is being tested now. The first TS's off the production line will be the final version. That is what the companies will base their buying decisions on. I'm confident that the Tesla Semi will be everything Elon has said it would be.
The one ton difference is the total weight difference, and the 500-600 mile range is the range fully loaded. Far too much is made of weight. Most loads are limited by volume, not weight, and given the likely cost savings from the Semi a one-ton weight difference is not that significant even when weight is the limiting factor. Imagine you are a transportation company CFO being presented with two choices -- the Tesla Semi or a diesel. The diesel costs 20% more per mile to operate, but 5-10% of the time it can haul 5% more. Which is the better choice? On HVAC, both diesel and electric trucks need it. Tesla has fantastic HVAC systems on its cars -- there is no reason it wouldn't have best-in-class HVAC in the Semi. Space would not be an issue for electric trucks any more than diesel -- if anything the opposite is true. Tesla cars have frunks because the small electric motors take up much less space and the battery is under the vehicle. The same will be done with the Semi. It also has a frunk, which is added space compared to a diesel truck, not less. Thanks -- yes these are production trucks but the point is the same. Initially fleet customers are buying in relatively low volume until they can put the Semi through the paces before ordering much bigger volumes. Elon estimated that they'll sell 100,000 per year after a few years, but if they have enough battery supply I think it will eventually be much more than that since the economics will strong favor the Tesla Semi over diesel. 100,000 Tesla Semi Sales Spells $18 Billion In Revenue
Tesla is hiring production line workers at Giga Nevada for the semi. Hopefully, 2021 will be the year the production Tesla semis hit the road.
Once zero-emission semi cabs become widely available, I can envision some municipalities regulating, restricting, or even outright banning their diesel counterparts (I'm looking at you California lol). Los Angeles is a perfect example, as they already have many regulations on atmospheric emissions due to the persistently-poor air quality. With less noise and air pollution, cities will likely start to encourage the use of ZEVs within their borders.
With BEV Semi's weight is everything. The weight of a battery pack has limits. Too much weight outweighs the benefits of having more batteries, as in range. 'Best-in-class' - sounds like an ad for Ford,GMC or Dodge trucks. LOL Do you work for an ad agency? With more space comes more weight. The reason for more space in a Semi is to have more room for storage such as gear, clothing, larger bedding, etc. All this means more weight which is more taxing for a BEV Semi than diesel. Giga Nevada, Giga Berlin and Giga Texas will manufacture the 4680 cells. Hopefully Giga Nevada and Texas can supply the demand for the Tesla Semi's.
I've already explained why a small weight difference won't overcome the economic benefits of the Tesla Semi so we will have to agree to disagree. I look forward to Tesla shaking up the trucking world even faster than the auto world.
It's worth noting that the about 300lbs of the car pack weight is the pack casing etc... The bottom has the 1/4" thick aluminum "ballistic shielding", whereas the side and tops are relatively thin material. So I expect that majority of the weight is divided between the bottom shielding and the internal structural members. As an individual casing would not be necessary around each of the 6-10 car-pack's worth of cells making up the Semi pack, as a percentage of overall mass the Semi pack would be smaller. It might be possible to build an entire semi pack casing for ~600-1,000lbs, rather than the 1,800-3,000 the math above would assume.
I wonder if there will be companies turning the semi into other types of vehicles Such as tow trucks, Rescue vehicles and even a cement truck
That won't happen anytime soon. Any modifications to the Tesla Semi's frame will void the warranty and wreak havoc on the software that is designed only for the original frame/structure. Maybe in the future Tesla will have something similar to Apple's Developer Program where a company can work with Tesla on getting an approved modification.
I'm not seeing a major weight issue. The front axle legal limit is 12,000 lbs. With the integrated motor axles, there is no frame torsion to deal with like on a diesel, so the overall structure can be lighter. That is assuming the trailer grossed out before it cubed out. That is not a typical case (at least in 2008): https://info.ornl.gov/sites/publications/files/Pub37730.pdf
Sure, for a fixed pack size. In a normal situation (far from maxing out the drive train capacity), more pack can offset the additional mass, including its own mass. Elevation changes, climate, and wind will have a larger (though variable) impact than an extra ton of weight (~2.5% change in rolling resistance if we are talking 78k lbs vs 80k).
