The time has come for charging in my condo !!!! but...
Discussion in 'Charging Standards and Infrastructure' started by squadra, Sep 13, 2016.
  1. squadra
    squadra Member
    Fort Lauderdale, FL
    I need your help guys !
    After over a year of begging for electric charging spots in my condo they are finally agreeing and on top of that they will do it how ever i want.
    I would like to know what is the best solution for any electric car to charge ?
    They will install 250V 50amps but I would like to make sure that we install the right thing for any other electric car to come and plug in
    Thank you !
  2. Rocky_H
    Rocky_H Active Member
    Boise, ID
    It is pretty widely recognized that Clipper Creek makes the most robust and reliable charging stations at pretty good prices. So I would go for a hardwired unit from them. The HCS-50 will use that 240V 50A circuit and supply 40A output, and it is $835. It is a J1772 format charging handle, so any electric car can use it. You can mount it on a 4 inch square wooden post if you want for cheap, but since it will be outside in the elements, a metal post might be better. Clipper Creek also has mounting posts, like the ProMount Duo, which is powder coated to protect from weather and rusting. It is $434. So that is a pretty decent universal usage setup.
    ClipperCreek EV Charging Stations | Reliable, Powerful, Made in USA
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    If you want to make a public station, look at EATON who has a credit card payment center/ key Fob to unlock, or a Chargepoint station if it is available in your area. Both are J1772.
  4. evotorentals
    Montreal
    Its great they are not making you pay for it.
    All the best!
