OK, with my Model 3 on order, I still haven't seen a discussion on this topic so will post it. I realize this is not unique to the Model 3, but can come up with any two Tesla's or EV's for that matter, but is certainly going to come up more with widespread Model 3 sales... the question is, have others found the 20' length of the included mobile connecter (charging cable) to be just a wee bit too short to allow convenient placement of the NEMA outlet for charging two Tesla's, or EV's?
Many of us who have a Model S or X quickly realize that you don't need to buy a dedicated wall charger, Tesla or otherwise, as you can use the included mobile connector (UMC) with just a NEMA 14-50 or 14-30 outlet - thereby saving at least $500 plus additional electrician costs, compared to getting a plain NEMA outlet installed. I would hazard to guess that the majority of Model S owners actually charge only with the UMC at home.
It also becomes fairly obvious at home that there are only two good places to put an outlet or charger, either on the left wall, or on the front wall of the garage. On the left wall, it's ideal to park one Tesla on the left so the charging cable does not cross over the other car. With two Tesla's, the cable will cross over one car to reach the other - it's inevitable, and can pose some risk if drivers do not look for the cable before leaving the garage.
Therefore the front wall becomes ideal. But the Tesla's are 15-16' long, and presuming you don't touch your wall with your bumper, you need about 14-15' just from the wall straight back to the charge port. That leaves a precious 5' or so of cable length for lateral positioning from the wall outlet to the charge port. Given that two cars charge ports need to be laterally about 7-8' apart, is it even possible to use one wall-mount mobile connector to reach both cars - and if so, is the possible span of mounting locations for the outlet nearly practically prohibitive?
In this case the extra 4' of the Tesla Wall Connector makes a big difference, and if that was their designed upsell, it's actually quite clever. So instead of asking why Tesla didn't make the UMC 25' instead of 20', what are folks doing to address the two Tesla charging cable conundrum?
-using left or right mounting cable mounting, which requires additional diligence (note it's impossible with one Tesla to drive with the UMC attached, the car will warn you, but with a 2nd Tesla it will not tell you whether you're about to back into the cable plugged into the OTHER car)
-using separate NEMA outlets and charging cables for each parking bay
-springing for the Tesla Wall Connector for the added 4' length
-getting a long or short cable extension, which has its own issues - additional resisitve losses, losing the idealness of the 90 deg turn at the plug in the UMC, etc
-any other creative options?
