Under the rain tray on the passenger side has the most room. There really isn’t enough room under the frunk liner for anything.
Is that where you're going to mount your pump?
Just checking for available space. I would put it there but it would be too loud. There’s enough room behind the passenger fog light, so I’ll put it there so it’s farther from the cabin. Acuallty going to start on that bracket tomorrow. The manifold will go there though, and the relays next to the oem relay on the wheel well behind the Frunk liner.Is that where you're going to mount your pump?
The only kit I know of for AWD on the market is the airtekk one. They are fixing the front struts being too long. So that problem will be solved for future buyers. And the rear needs the washers under the hat and the bolts pressed out. Not a big enough deal to not go with them IMO.Im thinking about going with an air setup over a conventional coilover set up since my coils have been on back order since January... I dont see any options for the AWD kit on Bagriders website, does anyone know if they are coming out with anything? Or any alternative options aside from Airtekk's since they look like a royal pain to install?
The 3H or 3P setups are awesome imo. Depending on how much you want to spend and the extra work of the height sensors.Is the accuair E level kit worth the price difference compared to the Airlift performance 3H kit? Ive literally always had coils in my old cars so I'm really new to the air scene. After your recommendation I'm looking at the Airtekk AWD kit paired with the Airlift performance 3H management kit. Any input or is there somewhere I can do a little more research you would recommend?
Side by side rear.
Direct bolt on my arse, this is the second mod I’ve had to do to get them bolted in. You’ll need to double up on the washer below the hat. I didn’t have one thick enough so I used 2 thinner ones.
It’s going to be a little while, I need my new shorter fronts sent to me. I’m working on the rest while I wait.Have you get it running yet ? Really want to get this setup but just not sure how it rides with bagover setup rather than bag and struts being separate in the rear. ( No aggressive driving, just comfort and noise feedback if possible)
Here’s the bracket I decided to do. An old piece of scrap I had. Going to add reinforcement before it’s final. Mounted to crumple support.
Do you have anything pics of how your air lines are ran in the rear wheel well? (Outside of the cabin)My 4 gal tank is a bit more stubby lol
Have you started your install yet?It's looking like i'll be going with Universal Air's Solution Series (bag & coilover setup). Spoke with Zack and they just need to see what the front AWD strut looks like (which I'll be providing) to make the AWD kit. Which will look something like this:
Also going with the Endo-CVT and Accuair e-level system as Universal Air already have sensor brackets for the model 3 to make the sensor install a bolt-on affair.
At first I wasn't sure about spending on the Endo-CVT setup, but after recalling what I went through with my first air install... I'd be glad to spend extra on this all-in-one contained unit. Should make install alot easier.
All done under the frunk liner. Tried to make it look as OEM as possible (other than the obvious fuses).View attachment 398377
I don’t want to pay the kind of money it would take to make a custom tank that could be hidden. But I do know where I would put it .That's super sweet. Wonder where the air tank you are going to hide ?
I've sent you a PMI don’t want to pay the kind of money it would take to make a custom tank that could be hidden. But I do know where I would put it .
View attachment 399666 View attachment 399667
Why did you have to add washers?
