They didn't use the jack point...
Discussion in 'Model S' started by Caligula, Jul 4, 2016.
Tags:
  1. Caligula
    Caligula Member
    San Diego
    Sigh. Even after showing them where the jack point is at the corner they needed to raise to fix a tire, the shop STILL managed to screw it up. I'm wondering how bad this is?
  2. Caligula
    Caligula Member
    San Diego
  3. sorka
    sorka Active Member
    Merced, CA
    Well, they damaged the bottom of the battery casing. Whether it turns into an actual issue with the battery later is another question.
    However, to me, this is like damaging the paint or any other part of the body. They have to make it right which is likely to be very expensive. Put another way, when I look for used cars to buy, I always get them on a lift and inspect them underneath. In this particular case, if I saw the damage from it being incorrectly lifted, I'd have to take a pass on your car or you'd have to knock a ton of money off the price to make it worth my while.
    I had wal mart mount and balance new tires for me a few months back. I of course brought the wheels and tires in. There was no way they were going touch my car. Even when I take my P85D to the service center, I take pictures of the rails on either side and make sure there's no damage when I get it back...same as the rest of the exterior.
    • Helpful x 2
  4. ToyotaJon
    ToyotaJon Member
    Dallas, TX
    Pretty sure it's just cosmetic. I had a Cayenne where the jack points had gotten damaged but when I took it to the Porsche service center they said it was just cosmetic and not to worry about it. I ended up selling the vehicle to a used car dealership and it wasn't brought up as an issue.
  5. Brunton
    Brunton Pontificating the obvious
    Summerville SC
    I would rip them a new one, and demand they fix the damage.
    I would also take the car to a service center ASAP and ask them to look at the damage and give you an assessment. I would tend to agree with ToyotaJon that the damage appears superficial, but take no chance. Even a slight possibility of a runaway thermal event is nothing to sneeze at.
    I just had my tires rotated at a Midas. A couple other places, including a car dealer, refused because of the potential liability, even though I gave them a printout of the page in the owner's manual about lifting the car. I appreciated their caution - if they were uncomfortable doing the job, I was uncomfortable having them try. Midas happened to have done another Tesla in the past, so they were experienced and happy to do it.
  6. Caligula
    Caligula Member
    San Diego
    I had a friend send pics to a Tesla mechanic. He said it looks superficial as well but to take it in to get it looked at. To make matters worse, these monkeys scratched the hell out of my wheel.
  7. int32_t
    int32_t Tesla Spotter
    Calgary area, AB, Canada
    How can they be told and still not ... never mind. :mad:
    Reeally going to watch out for things like this when I get my 3.
  8. Caligula
    Caligula Member
    San Diego
    It wasn't just told... I literally got on the ground and put my finger on the jack point to show the manager where to lift it. To top it all off, they scratched the hell out of my rim.
    Cliffs Notes: NEVER use American Tire Depot... even if you have a flat and it's the only store open on the 4th of July.
    • Disagree x 1
  9. int32_t
    I guess the message didn't make it down the food chain. He assumed his employees would take a moment to look for the obvious!
    Got to carry a spare. :p
  10. GasKilla
    GasKilla No Gas Know Peace
    Los Angeles, CA
    Where exactly are the jack points? For future reference.
  11. TaoJones
    TaoJones Beyond Driven
    The Americas
  12. murphyS90D
    murphyS90D Member
    Horsham, PA
    Just in case anyone is looking for the jack points they are not green. They are black plastic rectangles.
  13. Don85D
    Don85D Member
    Markham, Ontario
    The jack points are recessed so a normal hoist with flat pads will touch the flexible plastic trim. I made blocks with a one inch dowel in the centre to fit the jack points. I used plastic wood for the rectangular blocks but any similar material should work.
    I'll lift the car on my hoist for all minor servicing as I plan to keep the car for at least 30 years. For bigger jobs a Tesla Service Centre should have hoist pads to fit the car.
  14. artsci
    artsci Sponsor
    Timonium, Maryland
    That gives me an idea -- I think I'll spray paint the jack points green or use green wrap on them. Perhaps that will reduce the likelihood that the morons who did the OP's car would make a mistake,
    • Funny x 2
  15. ABCCBA
    ABCCBA Member
    Somewhere
    I have been told that Hockey Pucks work great as spacers to keep the jack from damaging the trim. I keep four in my car just in case.
  16. mrjedistud
    mrjedistud Member
    New York
    In my minds this is a design flaw on the part of Tesla. The unique lift points and the fact that they are recessed make for a hard time jacking up the car. They could have easily enlarged the rubber lift points to fit a standard jack.
    Based on your pictures it looks just cosmetic. Hopefully everything is fine.
  17. JPP
    JPP Active Member
    SF Bay Area, CA
    FWIW, the America's Tire shop I use in fact use 4 hockey pucks--fit perfectly, no damage.
  18. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I use a 6" piece of 2X4 which fits under the pad and protects against the larter jack pads.
  19. Caligula
    Caligula Member
    San Diego
    SvC did verify the damage is cosmetic and that it would cost $1500 to replace. Lol I'll send ATD the invoice.
  20. sorka
    sorka Active Member
    Merced, CA
    #20 sorka, Jul 6, 2016
    Your tire place got off lucky.
