I've had better luck with one of those sausage shaped filters that fit onto a garden hose. I use it to wash the car and fill up my outdoor spa. If you get a decent one for about $20, it lasts through a couple years of washing various things before it starts to get clogged up and need replacing.
Well, they are fairly easy to find and sold at lots of places. Type "inline water filter" in Google and several will come up. I've had great success with them, but it might depend a bit of where you live and water minerals are in the water. Most of these filter to a 100 micron level.Got a link?
Here is one that popped up in google. Not the one I use, but it gives you an idea of what they are like.
https://www.walmart.com/ip/Hydro-Li...hguid=a443a4e4-d1d-16baba20b4dd16&athena=true
Forget about the 8,000 - 10,000 gallon thing. I suspect that is for drinking the water since many of these are used in campers. For washing or filling hot tubs, it lasts a lot longer than that.
Can you post a link or picture as to what product you use? Sounds promising.I've had better luck with one of those sausage shaped filters that fit onto a garden hose. I use it to wash the car and fill up my outdoor spa. If you get a decent one for about $20, it lasts through a couple years of washing various things before it starts to get clogged up and need replacing.
I use a CR Spotless system and can wash the car in direct sunlight. I still have to be quick getting the soap off, but once it's rinsed, the water dries pretty quick with no spots (assuming it's in the sun). I wash in the morning or late afternoon when there is shade, but could do it any time of day if I wanted. More flexibility with my time, so no complaints.
I have the CR Spotless system as well and it works perfectly. I’ve also had very good experience with their customer service department. Not cheap, but works exactly as advertised and leaves no spots even when drying in the sun.
Is it only good for 300 gallons of filtered water before you need to replace resin and/or cartridges?
I have hard water and wondered if a water softener would stop the white spots and make drying easier. I usually use the leaf blower, but even then there are tiny white spots on the windows.
You want a deionizer not a water softener. They are different. A deionizer will give you a spot free rinse. Here is the one I recommend. Family operation. Give them a call before buying to discuss.
Buy this $10 TDS meter from Amazon before you call them. It will tell you how much stuff you have in your water and thus which deionizer is best for you. https://www.amazon.com/Sonkir-Drink...r&qid=1562032998&s=gateway&sr=8-2-spons&psc=1
Not sure your recommendation was attached for the deionizer...
