This Charger can't possibly work can it??
Sasmania
347
398
Scottsdale & Flagstaff AZ
I'm getting my second Tesla, so need to get a real charging solution vs using the mobile connector and unplugging it every time as I'm in a public garage.
Most of the new chargers are $500 or so including the Tesla one.
I found this on Ebay... for only $169. There is no inverter box or whatever the usual bulky thing is that comes with all the other power cords. So, I'm assuming this will NOT work, correct?
272436688390
araxara
S-P85#3,218 X-LR M3AWD
May 11, 2012
1,012
380
Tucson, AZ
That's just the J1772 charge cable without any electronics. It will not work on its own.
Actually, the Tesla HPWCs are a great deal. I would recommend installing 2 of them so you don't have to deal with switching the plugs around. Or you can just install one and continue using the mobile connector. But since you are in a public garage, Im not sure if they would allow you to install anything.
Since you will get another Tesla, it too will come with its own mobile connector. I don't really know what you are trying to solve.
Sasmania
347
398
Thx for the reply, I have two side by side parking spots, will have an S and X, and have one 14-50 plug that's free so no complaints there. However, it's a pain unplugging both ends each time so I can keep the mobile plug in the car and more importantly prevent it from walking off.
So, ideally, I install a permanent solution that allows me to not have to deal with the mobile chargers and just leave those in the cars. 2 is an even better idea, but especially since it's an apartment and not a permanent residence, I'd like to find the most cost effective solution in case I'm only here a year...
Rocky_H
5,848
6,684
Boise, ID
A wall connector with the 24 foot cord sounds like a great option. The wall connector can be installed on circuits from 15 amps up to 100 amps, so there is tons of flexibility. You can take the 14-50 outlet off, and mount the wall connector onto that circuit if you can have some kind of flat surface or post to mount the wall connector on. I guess another option would be if you can mount a small-ish box with a door that can be opened and closed and locked. That could keep the UMC secure when you're not using it.
kort677
Banned
Sep 17, 2015
4,801
2,241
florida.
if you are constantly unplugging your umc you should consider buying another one for the car or installing a permanent tesla wall charger.
Reactions: BerTX
